E-parking brake ?
Old Feb 17, 2013 | 05:51 PM
  #101
_zebra's Avatar
_zebra
well if somebody's so far up your butt that you'll hit them rolling a couple feet, then it's their fault & are liable in most states
Old Feb 18, 2013 | 12:19 PM
  #102
tuxnharley's Avatar
tuxnharley
Originally Posted by MikeyTX
You're referring to the Volt right ?
Actually, my Volt has been 100% perfect since day one - ZERO problems.
If you were alluding to the report of the so called battery fire incident, a few facts are in order. That was one case, which occurred on a crash tested prototype - 30 days after the crash test, and then only when the car was picked up with a fork lift which punctured the battery cells.
Yeah - a real first year design flaw there......................
Old Feb 18, 2013 | 12:35 PM
  #103
sprtplt's Avatar
sprtplt
If you were alluding to the report of the so called battery fire incident, a few facts are in order. That was one case,.. .
"General Motors Co. is making modifications to the Volt because of a SERIES of fires after test crashes of the plug-in hybrid vehicle. The fires were caused by a coolant leak that occurred when the car's battery pack was punctured during severe side test crashes by NHTSA."
Old Feb 19, 2013 | 01:40 AM
  #104
SCM_Crash's Avatar
SCM_Crash
Did you happen to read the part about how the crash tested Volts were not properly disposed of before they caught fire?
Electric vehicles and battery electric hybrids have to be handled differently than standard gas engine only vehicles.
Old Feb 19, 2013 | 02:09 AM
  #105
DXBC7's Avatar
DXBC7
6th Gear
Default C7 Hand Brake ??????
Does the new Corvette comes with a manual Hand Break
or an Electronic Hand Break - I hate all E-Breaks
Old Feb 19, 2013 | 02:10 AM
  #106
SCM_Crash's Avatar
SCM_Crash
Electric. Nothing is manual.
Old Feb 19, 2013 | 02:50 AM
  #107
SBC_and_a_stick's Avatar
SBC_and_a_stick
Lots of talk about electronic parking brakes in the new Top Gear episode. I'm glad they are raising awareness about these silly new e-gadgets.
Old Feb 19, 2013 | 03:11 AM
  #108
SCM_Crash's Avatar
SCM_Crash
Yes, because Top Gear is the best place to be informed about anything automotive.
Old Feb 19, 2013 | 04:07 AM
  #109
SBC_and_a_stick
Neither are forums. But both are good in terms of figuring out the enthusiasts' sentiment.
Old Feb 19, 2013 | 06:58 AM
  #110
GOLD72's Avatar
GOLD72
[SIZE=2]
Actually it isn't an emergency brake. It is a parking brake. Emergency brakes on cars disappeared a long time ago. ......................
As an old mechanic corrected me decades ago, "Son, trains have emergency brakes, cars have Parking brakes!! It ain't an emergency brake."
Old Feb 19, 2013 | 12:53 PM
  #111
theseal's Avatar
theseal
Wrong. It is (or should be) a redundant device independent of brake hydraulics or battery power, which progressively locks the drive wheels at the driver's command.
Old Feb 19, 2013 | 12:57 PM
  #112
SBC_and_a_stick
it's probably called a parking brake so that manuf. don't get sued. It's much easier to make a good parking brake, and you don't want to guarantee emergency features.
Old Feb 20, 2013 | 05:08 AM
  #113
SCM_Crash's Avatar
SCM_Crash
Fair enough.
Old Feb 20, 2013 | 06:11 AM
  #114
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Old Feb 20, 2013 | 06:55 AM
  #115
GOLD72's Avatar
GOLD72
Good luck if you think that a parking brake will stop you in an emergency at 70 mph if you have a complete hydraulic brake failure. There is a reason why the Feds mandated dual hydraulic brake systems in the mid 60's. It will stop you in the distance that it takes a train. You would be better served using both hands on the steering wheel attempting to steer out of trouble or lessen the impact.
Old Feb 20, 2013 | 12:57 PM
  #116
theseal's Avatar
theseal
you are always better off trying to steer around a situation than stop in front of it. but a proper backup brake most certainly will stop you from 70mph or more. if you pull it too hard, obviously you go for a ride (but you are still working the tires to slow you down). but i have prevented several potentially fatal accidents with a mechanical 'parking' brake. three times on track, and at least once on the street that i can recall.
case in point, 08 z06 at heartland park, stock brakes.... they started feeling the slightest bit mushy at the end of one lap, so instead of hitting 155 at the end of the straight, i cruised down at 110 or so to cool everything down. When I eased into the brakes to scrub off about 30mph going into turn 1, the pedal went to the floor and stuck there. Those great z06 brakes did the old 'flex the caliper so hard the pads, pistons, and fluid behind them shot out of the calipers' and I had zero brakes at all. because the brakes are hydraulically isolated diagonally instead of front to rear (gross negligence IMO), i had zero hydraulic brakes at all.
the e brake in the c6 is garbage, largely because of electronic interference with its mechanical application, but it worked well enough to slow me down enough to successfully slalom people, cars, trailers, walls, and small animals and get the car stopped.
many modern cars CAN'T do that and it is a criminally negligent oversight by a bunch of idiot electrical engineers.
Old Feb 20, 2013 | 01:52 PM
  #117
SBC_and_a_stick
Engineers engineer. I would not blame it on them, it was a management decision I'm sure of it. The enthusiasts in general also don't seem to realize when a lot of the fun components of the car get deleted. Some folks just buy their sports car to polish it every day.
To E-parking brake ?
Old Feb 20, 2013 | 02:44 PM
  #118
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Originally Posted by c54u
When the e-brake is on, it will hold the car. As soon as you give the car enough gas to go forward, the e-braked disengages automatically.
This is what happens on my CTS-V, and it works very, very well.
Old May 21, 2015 | 09:36 AM
  #119
user051728's Avatar
user051728
I haven't found a newer thread where all the wrong information in this one gets refuted.
There is park brake hardware in the rear wheel hubs. The only cars that do not have separate park brake hardware are the ones where you need a special turn key to retract the caliper when you change the brakes.
Furthermore, when you have an EPB if you apply it AT SPEED it typically applies the regular hydraulic brakes (like slamming on a brake pedal). Some cars apply them to all 4 wheels, others only apply it to the rear wheels (to mimic the older manual systems). If you hold the switch the hydraulic brakes are used until you get to a very slow speed (under 5 kph) at which point the cable brake is applied.
The EPB has a manual release ON THE MODULE to allow you to in case of no power release the cable brake.
The only thing I want to know is if the at speed braking is 2 wheel or 4 wheel.
Old May 21, 2015 | 10:05 AM
  #120
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
This thread should have been left dead!
