C7 at the "ring"
Old Mar 24, 2013 | 08:47 AM
Big Dan 427's Avatar
Big Dan 427
Originally Posted by Batman 357
The ZL1 certainly made a good showing.
Completely different animal, wouldn't you say?
Old Mar 24, 2013 | 08:50 AM
vette friend's Avatar
vette friend
Assuming the weight of the C7 Z51 will be close to the C6 Z51 (3300 or abouts) the ZL1 has it on power to weight (6.8 lbs/HP vs 7.4 LBS/HP). The Corvette has it on cg height. The Camaro has a lot more drag, but has larger tires. Not sure on down force. It will be interesting to say the least.
Old Mar 24, 2013 | 08:56 AM
Big Dan 427
Isn't the ZL1 suspension more track oriented also, the car is a purpose built track rat right?
Old Mar 24, 2013 | 10:28 AM
Kappa's Avatar
Kappa
Ehhh, sort of. Its built to stand up to track work better than most, but it's not GT3 RS or anything. I don't think the C7 Z51 will be any less aggressive than the Camaro.
The 991S ran a 7:38 at the Ring and I seriously, seriously doubt that the C7 will be slower in any way.
Old Mar 24, 2013 | 11:02 AM
skank's Avatar
skank
Originally Posted by Guibo
It has to be way better than that. If it's running close to Z06 times ,as GM says is happening at other tracks, then it'll be closer to a 7:35-7:40. This takes into account the C6Z's time being done over the full course, which generally adds about 5s vs today's timing method. Almost all times recorded today omit the ~200m stretch from the final corner to the new pit exit used by industry for staging laps.
As usual, you are totally clueless about this. We have discussed this at great length before. There are timing loops located throughout the track that monitors their segments. The new C7 will be down in the 7:20s right where the ZO6 is currently.
Old Mar 24, 2013 | 11:07 AM
pTr73's Avatar
pTr73
Originally Posted by Nitrous Oxide
There's no doubt we'll see a better time. I wouldn't be surprised to see 7:49. But I don't know why anyone should trust me on that.
I am hoping to see the C7 be close to if not better than the current Z06. The 7:30's would be nice!
Old Mar 24, 2013 | 12:17 PM
vette friend
In several videos, Tadge continually states that the C7 Z51 is faster than a C6 Grand Sport. He never references the Z06. I suspect it's because the C7 Z51 is somewhere between he C6 Grand Sport and Z06
Old Mar 24, 2013 | 01:57 PM
Kappa's Avatar
Kappa
That would be true if Tadge hadn't mentioned to C/D that the C7 Z51 was running comparable times to the Z06(probably not the Z07) at VIR.
Old Mar 24, 2013 | 01:59 PM
gthal's Avatar
gthal
Originally Posted by Kappa
That would be true if hadn't mentioned to C/D that the C7 Z51 was running comparable times to the Z06(probably not the Z07) at VIR.
I think the quote was "competitive" rather than comparable. I think the subtle difference indicates the C7 Z51 is getting close to but not matching the Z06. Still a great accomplishment but, in my opinion, an important difference. That also means the Ring times might be approaching Z06 territory but not matching them. We will eventually see one way or another.
My bet is faster then the GS by a meaningful amount but a step behind the current Z.
Old Mar 24, 2013 | 02:02 PM
sam90lx's Avatar
sam90lx
Do some research....not comparable lap times to the Z06.
Old Mar 24, 2013 | 02:21 PM
Kappa's Avatar
Kappa
Fine, competitive. Either way, its going to be a good bit faster than the C6 GS on track.
Old Mar 24, 2013 | 02:23 PM
sam90lx's Avatar
sam90lx
It better be or the C7 will be a complete flop!
Old Mar 24, 2013 | 02:24 PM
  #33
Kappa's Avatar
Kappa
If you say so.
Old Mar 24, 2013 | 02:36 PM
  #34
robvuk's Avatar
robvuk
Competitive with the Z06 means to me that it will depend greatly on who's driving.
Old Mar 24, 2013 | 02:41 PM
  #35
sam90lx's Avatar
sam90lx
A 13 Z06 with the Michelin tire is going to destroy the C7!
Please people!
Old Mar 24, 2013 | 03:42 PM
  #36
Guibo's Avatar
Guibo
And yet you still cannot confirm the name of the company that provides the timing, nor can you explain how the ZR1 and GT-R have slightly different starting points.
The torque curve and handling are much improved. And Michelin seems to claim that they have a couple of tricks we don't know about. That's why 10 seconds is probably not so unrealistic.
Ron Fellows found about 4s on only a 1:3x track (Road Atlanta) between the Z06 on Goodyear F1s vs the Michelin PS2s, and the Pilot Super Sports are even faster than PS2s. It's got to be 10s faster minimum. Key to the MPSS is that it keeps its shape better (a flatter profile flush with the road) as it heats up.
Old Mar 24, 2013 | 06:38 PM
  #37
skank's Avatar
skank
I've posted this before but you clearly did not read it. The company is Mylaps Pro Timing Systems. A company out of the Netherlands(next door to the Nurburgring). The ZR1 and the GTR do not have different starting points. You can clearly see it on the videos when both cars timing starts at the start ground loops and end at the finish line loops.
http://www.mylaps.com/index.php/us_e...car/references
To C7 at the "ring"
Old Mar 24, 2013 | 06:57 PM
  #38
Guibo's Avatar
Guibo
No, I did read it. Nowhere on that webpage does it say they are supplier to the Nordschleife. In your very next post, please prove that they supply to the Nordschleife. You have been asked for this proof before, but have failed to prove it.
I posted this in the other thread, but you failed to address it:
Note how far forward the ZR1 is when the timer starts (0:00.1 elapsed on GM's timer). The GT-R is way back further when it has already registered 0:00.21 on Nissan's timer. Notice the dividing point between the white portion of the fence on the right vs "unpainted." The ZR1 is right upon it when the timer starts, the Nissan is much further away with 0:00.21 already elapsed.
Note the difference in accuracy of the timers. In the beginning, GM's timer shows 0.0s discrepancy against the independent timer. Nissan's shows a delta of 0.07s. By the end of the lap, GM's time shows a 1.245s delta. Nissan's delta is only 0.115s.
Here is the commentary supplied by the person who matched those videos to an independent timer:
"Here is a video combining the GT-R (7:29) run with the ZR1 run (7:26) at the 'Ring.
Both GT-R and ZR1 runs are using the original videos in their original timeline (no time stretching). Both times are off with respect to each other. So I added a timer using Sony Vegas' timecode Video Event FX in its default settings.
The 2 videos were sync'ed at the point immediately before the 00:00:00 started to tick. It's also at this point where the Sony Vegas timecode was started. Actually, at this starting time, the ZR1 is already ahead (slight head-start). I could have used the landmarks to sync but I decided to trust the timings done by both GM and Nissan.
The Nissan timer is closer to the Sony Vegas timer (both end points). The GM timer seems to get an accumulated delay of a little more than 1 second. For example, when the ZR1 finished at 7:26.4, the Nissan timer was at 7:27.58 and the Sony Vegas timer was at 7:27.580. When GT-R finished at 7:29.03, Vegas timer was at 7:29.015. The best way to confirm which of these 3 timers is correct is to use your own stopwatch as this YouTube clip is played."
Old Mar 24, 2013 | 07:14 PM
  #39
Guibo's Avatar
Guibo
Carrera GT starting point (much closer to the GM starting point than the Nissan starting point).
Observe in the above picture that the Carrera GT has not yet cleared the pit-out wall edge and the clock already shows 0:00.20 elapsed. In the ZR1 video, the Corvette has already cleared that pit-out wall edge, with only 0:00.1 elapsed. @ 0:00.21 on the Nissan timer, the GT-R is nowhere near that pit-out wall edge.
Old Mar 24, 2013 | 07:19 PM
  #40
Davidl81's Avatar
Davidl81
I love how people on here are predicting how the C7 will do on the track when they have not even released final HP/TQ numbers.
