What a hoax. Ethanol the big government subsidy! It's a waste on so many different levels. And it destroys equipment. Oh ya, it helps stop global warming to.
It is avenue to a cooler running more powerful cars and you hate it? Politics? Do guys like you work for Exon or something? The ZR1 can heat soak at 638hp. Simply adding E85 could AUTOMATICALLY get it up to 680hp without the heat soak. Give me a Fricken Break!
im sorry but what are you thinking........lol
Ethanol is America's Gas. lol. plus it is a HUGE gain. the extra fuel means cooler combustion chambers. and the list goes on and on and on. .....
the higher compression of the LT1 will eat this stuff alive.
the c7 rpo code has flex fuel in it.... if gm does it right. you could be looking at a 10-15% hp gain of 91
[url]
If you need another 40hp in your $120,000 car you can spend your own money to mod it. I have no desire to have my tax dollars funding a proposition as absurd as american ethanol. Last I checked a gallon of ethanol that sells for $1.65 costs $1.92 in subsidies to produce. If it wasn't for the import tax placed on ethanol those dollars could buy 2 gallons of brazillian ethanol for each gallon those subsidies generate. Don't tell me that makes sense to you.
The Ferrari factory developed the updates to the fuel system and the calibration to allow the cars to run on alcohol. Running on E85 is expected to help improve the performance thanks to the increased octane rating of the fuel.
No, but I worked at EXXON's predecessor company, ESSO. That's me, back in 1958, with my mother standing next to me me(she owned the place).
I go out of my way to buy 100% PURE gasoline. No E10/E85 crap for me.
Neither does the 2014 Silverado(that uses the GenV engine in three versions) vs the 2013 Silverado that did support E85. Who said that GM doesn't learn from it's past mistakes.
Like I said. A total waste of American resources at so many levels. Ethanol requires more oil to produce a gallon of gas. Then you need to transport it to a refinery. It also takes food resources in what ever form you make the ethanol from. Then you need to re-manufacture engine parts to handle the corrosive junk. All this to get a little more HP. Nope! A total waste.
But, there very well may be some logistical problems with it in a high performance realm. It would be cutting edge, and only worth it in that realm.
And, unless you can invalidate the above information you haven't proven your point.
Anyway, if it does come in the C7 you can run yours on your gas to get spanked on a track day, and you can explain then?
THE OLD VETTES WERE DOGS!!!
You have some bad info there.
The LT1 is the GenV engine used in the C7 Corvette and we all know that it is a E0/E10 engine designed for 91 octane.
The three GenV engines used in the 14 Silverado are the LV3(V6 with 11: CR for 87 octane), the L83 V8 with 11:1 CR designed for 87 octane and the L86 V8 with 11.5:1 CR designed for 91 octane.
No GenV engine at this point is designed for E85 FlexFuel.
The only person that said that the LT1 will not be E85 ready also said that E10 was the absolute max. I can tell you that isn't true, even if E85 wasn't supported.
The government has already been pushing for E15 as the minimum E mix. That means that GM would be designing a car that wouldn't run in many areas of the country. California will likely be one of the first adopters of E15. California also happens to be the state where Corvettes sell the most. So that information is definitely incorrect.
When E10 was being pushed, the government gave all manufacturers a warning about it. In 1991, all cars manufacturers selling cars in America started supporting E10 for America-bound cars. The idea that GM wouldn't be supporting E85, let alone E10, on a DI vehicle is preposterous. Especially since GM loves to sell those flex-fuel vehicles.
