Showcasing E85?
Old May 3, 2013 | 11:41 PM
Z06-TT's Avatar
Z06-TT
Originally Posted by speedlink
Like I said. A total waste of American resources at so many levels. Ethanol requires more oil to produce a gallon of gas. Then you need to transport it to a refinery. It also takes food resources in what ever form you make the ethanol from. Then you need to re-manufacture engine parts to handle the corrosive junk. All this to get a little more HP. Nope! A total waste.
you will get more HP running e85 due to you can run more timing......safely
corrosive junk???? have you ever taken a motor apart that has ran E85?? it looks clean as hell...
i have a BUNCH of ethonal refineries in my state so i am fine with that. it brings money into my state and local market
Old May 3, 2013 | 11:51 PM
HurricaneRN's Avatar
HurricaneRN
Originally Posted by Z06-TT
post picture. or link please....
On a recent thread, last 24-48 hrs probably. I believe capless filler was in the thread or post title, shouldn't be too hard to find.
Old May 3, 2013 | 11:54 PM
Z06-TT's Avatar
Z06-TT
i googled it. and yes on the cap it says no e20-e85.... so can i run e98.lololol
http://forums.corvetteforum.com/c6-c...s-imposed.html
here is a old right up.... but i think time will tell. just find it funny that it is in the RPO code but you can use it...
guys i'll be the first guy to switch it over. i love the stuff.
sam90lx's Avatar
sam90lx
Yes, there is a pic of this somewhere.
Old May 4, 2013 | 12:03 AM
HurricaneRN
Do you love paying the income tax required to fund the $1.90 in subsidies it takes to produce each gallon of $1.60 ethanol.
Old May 4, 2013 | 12:09 AM
Z06-TT's Avatar
Z06-TT
i think there a a bunch of other **** i pay for that would **** me off more than that.....
i would atleast like a christmas card from the familes i am supporting.
but i understand. but even in the end if that was there then e85 would be 3.50 a gallon... i would pay that for it. the benifits out weight the cost to me.
Old May 4, 2013 | 12:25 AM
HurricaneRN
I hear ya. Im not against ethanol, i have a problem with stupid ideas that i have to pay for. If they are going to throw away money they should at least be upfront about it. Take the $1.90/gallon in subsidies and just import cane ethanol (better fuel) for $0.80/gallon, shut down the refineries but continue to pay every refinery employee and farmer exactly the same to not work. They could do that and probably still have a surplus of cash.
Old May 4, 2013 | 03:38 AM
Raitzi's Avatar
Raitzi
Old May 4, 2013 | 02:38 PM
johnglenntwo's Avatar
johnglenntwo
Default Thank You!?
Originally Posted by Raitzi
I have read that there are quality issues with it, and it varies all over so, yes, I was worried about that. It would be hard to have a warranty if you couldn't vouch for what was going in!
But, that guy working with the motor last year said, the fuel system was good up to something like four digits, which, would be good for a fuel that requires ~30% more fluid.
And I beleave he said the LT1 could make ~40hp more on E85!
They tried!
(And for the record I have heard most E10 is something like E6.)
Old May 4, 2013 | 03:23 PM
Raitzi's Avatar
Raitzi
All types have some variation even in specification and manufacturer has to take this into account. Even e85 spec says ethanol percentage is between 53% to 83%.
Old May 4, 2013 | 04:44 PM
Z06-TT's Avatar
Z06-TT
Gm's flex fuel sensor on all the cars today can read from e1 to e99.
so i would guess they can adjust the tune just the same. depending how much ethanol you have in the system.
then you can run e10, e20, e50, e85. what ever.
i have pro efi on my car. yes it is alot bit more adjance than like what GM's computers are but... in the end they use the same flex fuel sensor.
on the variations. the govnerment regulates that it use to have to be between e70-e85. now it is e51-e85.
in my town i have never seen less than e72.
They tried!
(And for the record I have heard most E10 is some like E6.)
Old May 4, 2013 | 04:58 PM
speedlink's Avatar
speedlink
Ethanol ruins more engines. As far as refinery's, I do not want to subsidize your state or any other state, in order to make gas that is more expensive, more corrosive, and yields less mileage. Makes no sense. At the same time takes a food supply away. This is wrong on just about every level.
If you want to use it for racing, refine yourself, but don't ask me to pay for junk!
Old May 4, 2013 | 05:28 PM
  #33
Z06-TT's Avatar
Z06-TT
you guys keep bring up it takes food away..... have you seen what potion size is at restaurants??? me taking a little bit of corn is nothing comparied to the daily food thrown away.... atleast im using it..
but you going to have to explain this corrosive thing. or how it ruins engines.... not trying to be rude. but i will need actually facts.
i have been running it it cars for years and do ALOT of e85 conversions on customers cars. never had the ethonal ruin anything if done properly.
Old May 4, 2013 | 05:38 PM
  #34
johnglenntwo
Default Epa!?
How does a manufacturer get a engine through when it can mutate so dramatically? Wouldn't the EPA be worried that they would approve the engine in a configuration that many, if not most, of the fanatical owners wouldn't even be using?
Many potential problems, but, an excellent concept, and theoretically possible!
Old May 4, 2013 | 05:40 PM
  #35
johnglenntwo
Default It's a great Concept!
American Le Mans Series Ferraris switch to cellulosic E85
Old May 4, 2013 | 05:43 PM
  #36
johnglenntwo
Default Maybe an Enable switch!
If they did the work then maybe they want, and will let, the owners pick up the tab. That might be a way to get around the EPA, but, probably blow the warranty?
Old May 4, 2013 | 05:50 PM
  #37
johnglenntwo
Default Hoax!?
This thing could be Photoshop city!
To Showcasing E85?
Old May 4, 2013 | 05:54 PM
  #38
johnglenntwo
Default Besides!
If it is Flexfuelable it will potentially always be having varying amounts of ethanol.
Old May 4, 2013 | 06:56 PM
  #39
HurricaneRN
http://www.gie.com/about_us/images_for_the_news/Ramesh%20Singh%20-%20NACE%20MP%20-%20May%202009%20-Ethanol%20Corrosion%20-1.pdf
Old May 4, 2013 | 07:49 PM
  #40
OnPoint's Avatar
OnPoint
The Consigliere
Five manufacturers (BMW, Chrysler, Nissan, Toyota and Volkswagen) are on record saying their warranties will not cover fuel-related claims caused by the use of E15 or higher. Eight additional automakers (GM, Ford, Honda, Hyundai, Kia, Mazda, Mercedes-Benz and Volvo) have stated that the use of E15 or higher concentrations does not comply with the fuel requirements specified in their owner’s manuals and may void warranty coverage.
The automakers' expressed concern is based on several studies, one of the latest of which was done by this group:
CRC Project: CM-136-09-1B
Intermediate-Level Ethanol Blends
Engine Durability Study
Prepared for:
Coordinating Research Council, Inc.
3650 Mansell Road, Suite 140
Alpharetta, GA 30022
Submitted by:
Henning Kleeberg
FEV, Inc.
4554 Glenmeade Lane
Auburn Hills, MI 48326
You can Google that study and pull it right up.
All the above refers to non-E85 capable vehicles. E85 capable vehicles don't have the issue, obviously.
