Battery Saver.....
Old Nov 13, 2013 | 12:42 PM
post-it's Avatar
post-it
Originally Posted by KenHorse
Did I say anything about CTEK? No I didn't.
There are plenty of decent maintenance chargers out there that work fine and are a fraction of the cost of the one GM sells for the Vette.
Thanks for playing
I don't want decent, I want the best or nothing.
Old Nov 13, 2013 | 01:02 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Psssst... don't tell anyone but the technology used in pretty much all quality maintenance chargers is pretty much the same. It's not rocket science.
(you pay for the bells and whistles and perhaps current capability more than the technology. For battery tenders, more than 1.5 amps current capability is a complete waste of $$)
Old Nov 13, 2013 | 01:06 PM
post-it's Avatar
post-it
Every market has it's leader. Apple, Samsung and for battery maintenance it is CTEK. Do some research!
Old Nov 13, 2013 | 01:08 PM
Glen e's Avatar
Glen e
yeah but what he is saying is there is nothing the ctek does that a battery tender or others do as well...you are paying for the corvette logo by GM....and it's not huge technology like apple or android does, to charge at 1.25 amp and sense how to 3 stage a batt charge (called intelligent chargers)
http://batterytender.com/products/au...fficiency.html
It does not really matter, the vette is only $100, but others are as good is the point...
Old Nov 13, 2013 | 01:17 PM
KenHorse's Avatar
KenHorse
Market leadership doesn't always mean superior technology (Betamax versus VHS comes to mind).
Anyway, do as you will..........
Old Nov 13, 2013 | 01:25 PM
mt. view's Avatar
mt. view
I took the lights out in the back, they come out easy and unplug easy, then I set the hatch down, run the cord down the side with some towel protection, then put the cover on..works great. I would never slam the hatch shut with the cord in there
Old Nov 13, 2013 | 03:36 PM
StevieK's Avatar
StevieK
Originally Posted by JWLaRue
On my C6 I routed the wires from the battery out the left side of the front grill. I have a quick disconnect right at the grill that allows me to...well disconnect and then tuck the wire/plug back inside the grill area.
I've even managed to forget to disconnect it and back out of the garage...the quick disconnect simply separated.
I don't know if that's possible with the C7, but that's what I will try doing.
-Jeff
I did the same thing as you did with my C6 and backed out of the garage but the quick disconnect didn't separate, it broke. Problem with that connection now is where do you hook up to a viable 12V connection in the engine compartment now that the battery is in the back. I think I'll use CRABByJ's idea and just put up a sign on the windshield that says "charging".
Old Nov 13, 2013 | 07:19 PM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
Wasn't there a vender of the forum that manufactured a pretty smart little quick disconnect that ran the charger cable out from under the grill?
Old Nov 13, 2013 | 07:39 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
Yes this one is made for the C6 grill, I am waiting for the C7 item.
http://www.qpcpv.com/topflightreproductions/index.html
Does anyone know where the battery terminals are under the hood?
Old Nov 20, 2013 | 03:19 PM
StevieK's Avatar
StevieK
The positive terminal, in the first picture, is alongside the fuse box on the passenger side closest to the windshield. It's covered by a plastic cover which you can flip up from the fender side.
The second picture is the positive terminal after flipping up the cover.
A good ground, the third picture, is located on passenger side down and to the right of the alternator
Old Nov 20, 2013 | 03:58 PM
MoabC7's Avatar
MoabC7
Thanks.
And you can drop the 12v line down to underneath the car and not have to leave the windows cracked or the wire mashed onto the weather seal, and put the cover on for the winter.
Last edited by MoabC7; Nov 20, 2013 at 04:03 PM. Reason: Added comment/suggestion.
Old Nov 20, 2013 | 05:43 PM
green2000's Avatar
green2000
Originally Posted by MoabC7
Thanks.
That's great. Too bad GM could not have told us this important information.
Old Nov 21, 2013 | 09:23 AM
  #33
george vee's Avatar
george vee
Originally Posted by StevieK
The positive terminal is alongside the fuse box on the passenger side closest to the windshield. It's covered by a plastic cover which you can flip up from the fender side.
This is the positive terminal after flipping up the cover
Here's a good ground located on passenger side down and to the right of the alternator
Old Nov 21, 2013 | 10:17 AM
  #34
MoabC7's Avatar
MoabC7
What's the trick to releasing the plastic cover. I've tried, but it's being ornery and I don't want to break it.
Thanks.
Old Nov 21, 2013 | 10:26 AM
  #35
green2000's Avatar
green2000
Thanks.
This works somewhat for me. Try to slide the cover rearward while pulling it up. Once it is open then maybe you can file down a tab. I don't like the idea of having such a tight cover on the positive terminal as you may be tempted to use a prybar and short something out.
Old Nov 21, 2013 | 10:43 AM
  #36
MoabC7's Avatar
MoabC7
So simple. Mine released fairly easily with that rearward pull & lift. Thanks.
Old Nov 29, 2013 | 11:07 PM
  #37
robertbruce's Avatar
robertbruce
Can you use this terminal for an aftermarket battery tender?
Can you use this terminal for an after market battery tender?
To Battery Saver.....
Old Dec 1, 2013 | 09:33 PM
  #38
Hotrodpt's Avatar
Hotrodpt
Yes - but what I did was use a spot on the alternator. Before I plugged my charger (2 amp setting) in, I checked the voltage with a tester on the clips so I knew it was a good ground. Turn it on and you're home free. It took 2 hours to go from 12.3 to a fully charged state of 13.0 volts (checked with ithe charger disconnected to get a true reading).
Old Dec 1, 2013 | 10:00 PM
  #39
Patman's Avatar
Patman
Why don't you guys just get a charger that hooks up to the cigarette lighter outlet? That's what I did with my C5, and am doing with my C6.
Old Dec 1, 2013 | 10:52 PM
  #40
fireinv38's Avatar
fireinv38
Default Don't do it!!!!!!!
i have investigated a number of fires caused by power cords having external stresses applied. The application of stresses(closing door/trunk) may cause resistive heating leading to a fire. i have been a fire investigator for almost 30 years and have seen numerous car charger fires. just finished an investigation involving an original "Morgan" on a charger. find a way to keep external stress off the cord. same holds true in your house. don't put power cord under carpeting or under a piece of furniture. i don't need any more business. "Be Safe".
