Battery Saver.....
Old Nov 12, 2013 | 06:24 PM
StevieK's Avatar
StevieK
Default Battery Saver.....
Sorry if this has been answered already but I couldn't find anything about it doing a search.
I have a Battery Tender Jr. that I used on my C6 and I will use it through the battery port in the trunk of my C7. Question: How the heck can you close the hatch in order to keep the lights in the trunk from staying on? I know they should go out in about 20 minutes automatically but I never had much luck before with GM electronics and even if they did go out, 20 minutes is quite a drain on the battery.
Old Nov 12, 2013 | 06:29 PM
Glen e's Avatar
Glen e
slam the trunk, the weather strip will seal around the cord....that the way the optional gm accessory works...
Old Nov 12, 2013 | 06:33 PM
robertbruce's Avatar
robertbruce
I have been using my battery tender in my new c7 for the last month and I slam the door on it with no problems.
Old Nov 12, 2013 | 07:17 PM
cb98coupe's Avatar
cb98coupe
I was coming on here to ask the same question as the OP . I bought the optional battery tender with my car from the factory . I could not figure out how to use it . I guess I will slam the trunk.....
Old Nov 12, 2013 | 07:23 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
(can't see paying $100 for something I can get locally for $29 from NAPA )
Old Nov 12, 2013 | 07:26 PM
HalfMoon's Avatar
HalfMoon
But does the one from Napa have the flags logo?
Licensing fees and all that.
I'm going to use my expensive one I got with my c6. Needs to last at least 2 cars.
Old Nov 12, 2013 | 07:46 PM
FrancisDGarcia's Avatar
FrancisDGarcia
Just tried it and it works. I will keep the battery charged until tomorrow morning.
Old Nov 12, 2013 | 07:47 PM
dcbingaman's Avatar
dcbingaman
CTEK 3300. Greatest device since slice bread.
Old Nov 13, 2013 | 07:42 AM
post-it's Avatar
post-it
Is this the CTEK 3300? The least costly CTEK on Amazon is $67 plus $11 for the Cig adapter needed for the C7. The one from GM has the Cig adapter hard wired to the unit and the cord length is the correct length for easy use.
Old Nov 13, 2013 | 07:45 AM
robertbruce
Same one KH doesn't know what he is talking about.
Old Nov 13, 2013 | 08:14 AM
CRABBYJ's Avatar
CRABBYJ
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
Almost too perfect for me as I have it screw mounted waist high on the front of my work bench with more than enough power cord and 12v end to reach my C7. It is so inconspicuous with the 3300 being small and the rear hatch closed I fear forgetting to disconnect it when about to take a drive.
So I made up a 6" x 11" card sign that says "CHARGING" and placed it on the windshield. Tough being over 70 sometimes.
Old Nov 13, 2013 | 08:49 AM
FrancisDGarcia
Very good idea. I will do the same, but more for my wife. She drives the C7 sometimes and may not know it's charging at the time.
Old Nov 13, 2013 | 09:05 AM
rponfick's Avatar
rponfick
Closing the rear hatch on the power cord has been mentioned. Can't you just leave the window cracked about an inch and snake it through? Does that bother anything? I will have the car under a cover, but the cord on my quad battery tender is plenty long.
Just asking. Ralph
Old Nov 13, 2013 | 09:21 AM
CRABBYJ's Avatar
CRABBYJ
Just asking. Ralph
It may be easier to leave the door window up and route the 12v cord along the rear side of the open door closest to the quarter window. So that when you close the door the window indexes to the top. I would be concerned that critters entering my garage have easy access to the interior. Try that.
Old Nov 13, 2013 | 09:50 AM
nichtlangsam's Avatar
nichtlangsam
It always amazes me how we have to save $70 on an $80,000.00 car.
Old Nov 13, 2013 | 10:05 AM
Racerdj's Avatar
Racerdj
You could not start the 458 if the charger was plugged in.
Old Nov 13, 2013 | 10:16 AM
HalfMoon's Avatar
HalfMoon
So, that's where that extra $200k went.
(that was a joke, if it wasn't obvious).
To Battery Saver.....
Old Nov 13, 2013 | 10:42 AM
Stein's Avatar
Stein
From: Yopper of 52'yrs presently reside in WI Wisconsin
On my C6 I just routed on the bottom of the door. There were notches that the cord would fit in, like two little v-grooves. One toward the front and the other toward the rear of the door. I will have to see if the C7 still have these.
Old Nov 13, 2013 | 11:26 AM
KenHorse's Avatar
KenHorse
Did I say anything about CTEK? No I didn't.
There are plenty of decent maintenance chargers out there that work fine and are a fraction of the cost of the one GM sells for the Vette.
Thanks for playing
Old Nov 13, 2013 | 11:56 AM
JWLaRue's Avatar
JWLaRue
On my C6 I routed the wires from the battery out the left side of the front grill. I have a quick disconnect right at the grill that allows me to...well disconnect and then tuck the wire/plug back inside the grill area.
I've even managed to forget to disconnect it and back out of the garage...the quick disconnect simply separated.
I don't know if that's possible with the C7, but that's what I will try doing.
-Jeff
