what did you use to remove emblems?
Old 12-01-2013, 06:43 PM
VRMMMM
VRMMMM's Avatar
Default what did you use to remove emblems?
I got the stingray emblems off with a heat gun, and plastic scrapper. My problem is the adhesive GM uses. I have tried bug and tar remover, different waxes, but cant seem to get it all off. Any specific products that worked well for you?
Old 12-01-2013, 06:45 PM
millpond
millpond's Avatar
Goo Gone works.
Old 12-01-2013, 06:49 PM
Glen e
Glen e's Avatar
Received 1,023 Likes on 528 Posts
The black GM stuff is tough ...take your time, keep it wet with goo gone and work it with your finger, right side came off easily, left side was a bitch....
Old 12-01-2013, 06:50 PM
VRMMMM
VRMMMM's Avatar
I was trying to heat it up and use bug remover, but it just smears around. I will pick up some goo gone tomorrow and try that.
Old 12-01-2013, 06:53 PM
ByByBMW
Support Corvetteforum!
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Try WD-40. IT has worked pretty good on lots of stuff.
Old 12-01-2013, 07:27 PM
VRMMMM
VRMMMM's Avatar
WD 40 for the win. That and my finger nails got it all off. Just takes some time.
Old 12-01-2013, 07:36 PM
ByByBMW
ByByBMW's Avatar
Old 12-01-2013, 07:42 PM
HolyRoller
HolyRoller's Avatar
Firecrackers, where legal.
Old 12-01-2013, 08:38 PM
tome
tome's Avatar
I used WD40; works like magic and won't harm the paint.
time2run
time2run's Avatar
St. Jude Donor '13-'14-'15
I took the Corvette script off the back side of my C7 using 3M auto adhesive remover. Worked 10 times faster than Goo Gone and didn't harm the paint or clear coat.
You can buy it at most auto parts stores. Use it in a well ventilated area- it'll get you higher than a six pack of Jack Daniels.
Old 12-01-2013, 08:41 PM
0Airbrush Inc
Former Vendor
Airbrush Inc's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
I use PPG grease and wax remover. I will usually tape a piece of cloth to the area, then saturate the cloth to keep it moist. After 5 or 10 minutes, I'll then start removing the adhesive.
Old 12-01-2013, 09:29 PM
BPhillyc8
BPhillyc8's Avatar
Don't laugh. Try vegetable oil. It works.
Old 12-01-2013, 10:15 PM
C7GrandSport
C7GrandSport's Avatar
Dental floss
Stoner Xenit
3M Rubbing Compound
Then I put new ones on
Old 12-01-2013, 10:17 PM
66dreams
66dreams's Avatar
Old 12-01-2013, 10:47 PM
jr3
jr3's Avatar
Old 12-01-2013, 10:56 PM
toddwill
toddwill's Avatar
I like them and left them on...but on other cars Goo Gone has worked.
Old 12-02-2013, 02:43 AM
indy 28
indy 28's Avatar
3M adhesive remover or monofilament fishing line
Old 12-02-2013, 04:13 AM
Keep 'Em Flying
Keep 'Em Flying's Avatar
Originally Posted by millpond
Goo Gone works.
Old 12-02-2013, 06:48 AM
hcvone
hcvone's Avatar
Received 1,772 Likes on 971 Posts
I have been removing them for 35 years with this above method, many products remove the glue but nothing works better than the 3M Adhesive Remover because it made for this.
To what did you use to remove emblems?
Quick Reply: what did you use to remove emblems?
