GM Batt Tender Solid Product?
Old Dec 6, 2013 | 08:39 PM
Jbal's Avatar
Jbal
Default GM Batt Tender Solid Product?
Folks;
Looking at purchasing the GM battery tender, which apparently plugs into the cig lighter. Any thoughts or experience appreciated!
Thanks-Jerry
Old Dec 6, 2013 | 09:07 PM
MikeC4C5C6...C7's Avatar
MikeC4C5C6...C7
Mine is working so far as it should but I have only been using it for two weeks.
Old Dec 6, 2013 | 09:16 PM
Speednet's Avatar
Speednet
Yup, works great. Plugs into the outlet in the trunk. Couldn't be easier. Buy it with the car and it will be covered under the warranty with the car.
Old Dec 6, 2013 | 09:50 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I have one I use for my Corvette and one for my Camaro and they work great and car fires up every time after a nap.
Old Dec 6, 2013 | 09:51 PM
Jbal's Avatar
Jbal
Thanks Guys!
Jerry
Old Dec 6, 2013 | 09:56 PM
ta70raiii's Avatar
ta70raiii
CI 6-7-8-9 Veteran
I haven't checked. Is the outlet in the trunk (which I have never noticed) the only one that is hot all time?
Old Dec 6, 2013 | 10:13 PM
Speednet's Avatar
Speednet
Yes
Old Dec 6, 2013 | 10:34 PM
Jbal's Avatar
Jbal
Speednet;
Did not order Battery protection (ERI) w/my new C7. So simply plug into the Cig lighter.
Then works? Thanks! Jerry
Old Dec 7, 2013 | 03:17 AM
Virtual Geezer's Avatar
Virtual Geezer
Wow! Does C7 even have cigarette lighter and ash tray???
Old Dec 7, 2013 | 07:16 AM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
No. Only a receptical for a lighter and no ashtray, although I believe one can be ordered as an accessory.
The manual states that you must use the plug receptical in the trunk to charge the vehicle. I initially tried to plug the battery charger into the cigarette lighter outlet but it would not work.
Old Dec 7, 2013 | 10:57 AM
-CM-'s Avatar
-CM-
Only if you get the smoker's kit.
Old Dec 7, 2013 | 12:11 PM
Wormwood's Avatar
Wormwood
Not trying to hijack the thread but it's on a similar subject but can anyone say what kind of battery the C7 comes with?
Since some of the subsystems systems still operate after the car is shut off & yet it has to maintain enough juice for starting a V8 for the next drive cycle. I would imagine it may be more of a deep cycle battery as well as a starter. Maybe a hybrid style battery, has anyone look at the battery? Is it OEM to GM? Do we know GM uses for batteries?
Just thinking about an optima or oydessy, don't think a light weight lithium would be best in the situation.
Steve
Old Dec 7, 2013 | 05:07 PM
Jbal's Avatar
Jbal
Folks;
One more question. For those using them batt tender, where does the cord exit the rear of the C7?
As always, thanks-Jerry
Jbal's Avatar
Jbal
Folks;
Old Dec 7, 2013 | 05:25 PM
VNAMVET's Avatar
VNAMVET
Originally Posted by Jbal
Folks;
The right rear side of the car, between the hatch and the fender. I totally close the hatch. I have only used the battery tender twice just to see if it works.
Old Dec 7, 2013 | 06:24 PM
Speednet's Avatar
Speednet
It's a thin wire; you just close the hatch with the wire running over the rubber seal and it's fine. Be sure to wrap a microfiber towel or something around the wire to keep it off the paint.
I wrote in another thread that I wish GM would add an external tender outlet under the bumper or something.
Old Dec 7, 2013 | 06:41 PM
bluman's Avatar
bluman
It's a CTEK 3300, you can find it on the web for cheaper ($50-60), I have been using it for 5 years and it's awesome !
To GM Batt Tender Solid Product?
Old Dec 7, 2013 | 07:51 PM
Jbal's Avatar
Jbal
OOPS Folks! Sorry for the double thread! Thanks Speednet & VNAMVET. Comments very helpful, & will order this evening!
Thanks Again-Jerry
Old Apr 9, 2014 | 09:35 PM
GRG's Avatar
GRG
Default C7 Factory battery protection
Can you plug it into the cigarette lighter, the receptical in the trunk or either one?? Sorry just not sure.
Old Apr 9, 2014 | 09:38 PM
Glen e's Avatar
Glen e
There is nothing specials bout the Vette batt, no AGM or any other type of advanced construction.
