What size blind spot mirrors are ya'll putting on side mirrors?
#43
You guys are afraid of the looks "stick on mirrors" provide but I'll bet you are still wearing straight leg jeans, shirt tucked in, with white sneakers....so 80's!
#44
Received 2,242 Likes
I used the "stick on" before I was instructed at a Performance Driving Class about how to adjust the side mirrors out. The major problem with the little and they are all little, stick on is that at night and especially at night in the rain they are totally, yes totally, useless. Adjust your mirrors correctly and learn how to use them.
#45
I just think for the price and hype of the all new designed and advanced Corvette, that Blind spot monitors would of been though about. Even my older Chevrolet Pick up has these, and didn't pay anywhere near 70k. Just no excuse, think about it they put a backup camera and overlooked this?
#46
as karl marx said, ''nice weather is the opiate of the masses.'' [i think i got that right]
#47
E-Ray, 3LZ, ZER, LIFT
Received 9,679 Likes
I heard on the boards that the blind spot on the left side is pretty severe unless you get a little round mirror from walmart. I am going to be picking up the car and driving it back maybe in harsh weather and need to have mirrors with me. How big of blindspot mirror 1/2 1" 1.5" 2" what do ya'll suggest? And can you really find them in wallymart?
After driving for two months have found the blind spot mirrors are a big help, even after positioning the main mirrors as suggested to "eliminate blind spots." In the C7 that only partially works. Took pictures of what is visible, and not, with the Vette parked between two cars. Also shows how to "correctly" set the main mirrors. Pics are on my web site netwelding.com/reports_vette_info.htm
#48
Maxi View Blind Spot Mirrors
See The Difference!
Only Maxi view mirror has a 360° ball and swivel for full focus capability:"
Three times larger view than any other stick on.
Change lanes and parallel-park without taking your eye off the road.
Never strain or a twist your neck again.
Mounted in the upper inside corner of your side view mirrors it will never block your rear vision.
Installs in minutes.
Actual size: 2 1/2″ by 1 ¾"
See The Difference!
Last edited by Zymurgy; 12-12-2013 at 09:36 AM. Reason: Removed link - non-supporting vendor
#51
The spot mirror is so corner auto parts store junk.
Replacing with a convex mirror would be better as suggested.
Or just position your existing mirror properly and use them often as needed.
