Mirror Mount
Old Dec 14, 2013 | 01:14 PM
sajonf's Avatar
sajonf
Originally Posted by dmsick
I have the Savvy attachment which uses the onboard diagnostic port.
That looks like a sweet solution. I have an Escort but could move that to my other vehicle and purchase a V1. Does the OBD port provide switched power or is it powered all the time?
Old Dec 14, 2013 | 01:15 PM
robertbruce's Avatar
robertbruce
Here is a dumb question for you. Where is the diagnostic port?
Old Dec 14, 2013 | 01:43 PM
dmsick's Avatar
dmsick
goes on and off with the car. it's pretty sweet.
Old Dec 14, 2013 | 01:44 PM
dmsick's Avatar
dmsick
it's near the hood release. it looks like a computer port.
Old Dec 14, 2013 | 01:48 PM
robertbruce
Thanks. I appreciate it.
Old Dec 14, 2013 | 05:58 PM
coupeguyz51's Avatar
coupeguyz51
Mike at Blendmount emailed me that they will have one out for the C7 Passport Max in 3 to 4 months....
Old Dec 14, 2013 | 06:42 PM
Rob4092xx's Avatar
Rob4092xx
The problem with Blendmount is the cost! There are similar mounts for less than 1/2 the price!
Old Dec 14, 2013 | 08:04 PM
Goaty's Avatar
Goaty
They are pricey but you are paying for OEM-like quality. None of the others work as well as the Blendmount.
Old Dec 24, 2013 | 08:07 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Default Fix Vibration with Passport Max in Sticky Mount
Fixed a problem with my Passport Max mounted in the new "Sticky Mount." Although I like the new mount, the detector was vibrating excessively. Called Escort Tech but no help. found a solution in a detctor forum and a simple source for the dense foam piece added which solved the problem. This is a pic:
Full details are at the end of the free PDF of the C7 wiring details available on my web site: www.netwelding.com/reports_vette_info.htm
Old Dec 24, 2013 | 09:33 AM
sajonf's Avatar
sajonf
FYI I did some research and the V1 Savvy accessory works with the Escort Passport 8500. I ordered one and indeed it does work. I wired my Escort to the Savvy in the OBD port and it works like a charm
Old Dec 24, 2013 | 10:29 AM
robertbruce
Do you think it would work with the 9500?
Old Dec 24, 2013 | 10:30 AM
sajonf's Avatar
sajonf
Sorry I got the number wrong. I have a 9500 so yes it will work!
Old Dec 24, 2013 | 10:34 AM
  #33
robertbruce
Did you have to splice the 9500 end in to the vi savvy end?
Old Dec 24, 2013 | 10:53 AM
  #34
sajonf's Avatar
sajonf
I purchased an 8' cord that had an RJ11 connector on each end from ebay.
Old Dec 24, 2013 | 11:10 AM
  #35
khoeysr's Avatar
khoeysr
Corvette fan
Blendmount does not have a C7 specific mount yet. They say they are working on it.
Old Dec 24, 2013 | 11:23 AM
  #36
robertbruce
Thanks for your help. I looked up the part (20220)on the Valentine site so I should be all set to go.
Old Jan 23, 2014 | 04:15 PM
  #37
TRC7's Avatar
TRC7
Default C7 Radar mirror mount
Who sells the Mirror mount for the Escort 9500 that fits the c7
If you want to mount your escort or V1 under your mirror then contact Ed at Great Lakes Trophies. I have used his C7 mount and it works great and the price is right. He has done custom work on the bracket so it fits the C7 mirror.
Great Lakes Awards, LLC
32635 Ford Road
Garden City, MI 48135
P: 734-266-1815
F: 734-266-1817
www.greatlakestrophies.com
To Mirror Mount
Old Jan 23, 2014 | 05:01 PM
  #38
azvetters's Avatar
azvetters
Default ED @ GreatLakes
32635 Ford Road
P: 734-266-1815
F: 734-266-1817
I have mine on my c7 for at lest 3 weeks and no Vibrate no problem. worksGreat..
Old Jan 23, 2014 | 05:37 PM
  #39
rsl2715's Avatar
rsl2715
Mounted just behind the HUD screen with velcro,works good power from accessory power supply.Good news when you turn the car on it comes on and when you turn the car off and open the door it goes off.I used the original supplied coil cord.It does not look bad.
This was the easy way.With no power source on the mirror the only to go for me.
Old Jan 23, 2014 | 05:56 PM
  #40
dmsick's Avatar
dmsick
32635 Ford Road
P: 734-266-1815
F: 734-266-1817
Can you post a pIcture of the mount with the detector installed?
