Transmission problem?
Old Dec 26, 2013 | 12:48 PM
floraneg's Avatar
floraneg
Default Transmission problem?
Hello all,
Not sure what is going on, but it seems as if my Z51 may be having a transmission issue (VIN# 8913). I have 600 miles on the car and from the very beginning, it has felt sluggish and seems to change gears very slowly. To me, it has a very apparent delay when you step o the gas. Yesterday, I decided to give it a little push and got it up to 105 mph coming off of a very long bridge here in New Orleans. As I came to a red light after the acceleration, the car seems as if it did not down shift properly and the engine was revving very high, but not moving. As I came to a complete stop, I felt a "clunk" and the engine rev's came down. I've been reading about the rev-match and the issues some have voiced with it. Seeing that I'm VIN# 8913, I would figure that it isn't because of the lack of transmission oil as some have reported in earlier VIN#'s. I don't know if it is me, but it just doesn't seem to have any pickup when you step on the gas. I mostly drive in sport mode, which is where it was when this happened.
Any insight is greatly appreciated.
Old Dec 26, 2013 | 01:25 PM
Landru's Avatar
Landru
Get your car back to the dealer w/ a detailed account of your experience, here. Given your description something's wrong, sluggish' is not what these new C7s are.
Good luck, hoping whateveritiswrong can and will be rectified & DO keep the forum appraised what happens.
Old Dec 26, 2013 | 01:59 PM
speedlink's Avatar
speedlink
Rev match is used in the manual transmission. You seem to have an auto.
The transmission oil you asked about is not the issue. The problem you might have been referring to was the edif fluid. This doesn't relate to the problem you might be having.
Take it to the dealer and have them evaluate.
Let us know how it turns out.
Old Dec 26, 2013 | 03:27 PM
GRG's Avatar
GRG
Stopping at the red light and then a sluggish take out is because it is not down shifting into the gear you would usually take off in. The clunking noise is made when you give it enough gas on the sluggish take off that it makes the transmission downshift into first. Could be a bad shift solenoid or there may be metal particles in the fluid that are causing problems. Bottom line it is not right and needs to go to the dealer for warranty work or trade it in on a 2015 which will have an eight speed auto trans. Good luck.
Old Dec 28, 2013 | 12:35 AM
jamesw95's Avatar
jamesw95
Stop driving 105mph on public roads, see if that helps.
Old Dec 28, 2013 | 02:39 AM
Second Vette's Avatar
Second Vette
Van Halen:
I can't drive a Hundred and Five....
Old Dec 28, 2013 | 03:17 AM
Wormwood's Avatar
Wormwood
If the OP is operating an Automatic C7 in Tr-track mode & manually shifting the gears, it won't shift anything for you EXCEPT if he puts the vehicle close to doing internal damage to the engine, trans, or other systems. This could be even worse, if he entered into any of the Performance Driving Modes.
Isn't that correct or am I dream that little blonde in the C7 tutorial videos said that???
Wormwood
Old Dec 29, 2013 | 08:19 AM
pgway's Avatar
pgway
Hello all,
Why is anyone responding to this nonsence?
He obvioulsy has no clue and probably doesn't actually own a C7!
Automatics don't have rev matching!
No reports for a lack of transmission "oil".
He's either a FAKE or JUST STUPID!
Old Dec 29, 2013 | 09:28 AM
9157's Avatar
9157
Naples FL
The A6 does have rev matching!
Old Dec 29, 2013 | 09:38 AM
ldepalma's Avatar
ldepalma
uh, your joking right????? We all know the A6 does not have rev matching. It has paddles to shift manually but that's it. Only the 7 speed has rev matching.....
Old Dec 29, 2013 | 11:03 AM
9157's Avatar
9157
Naples FL
Wrong!!! Read the specs...drive one and you will see!
Old Dec 29, 2013 | 12:00 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Page 9-32 of the Owners Manual:
Active Rev Match
Vehicles equipped with a manual
transmission
[emphasis added]
have Active Rev Match
(ARM). ARM aids in smoother
shifting by matching the engine
speed to the next selected gear. By
monitoring shift lever and clutch
operation, ARM adjusts engine
speed to match a calibrated value
based on gear selection. On
upshifts and downshifts, engine
speed will be increased and
decreased to match vehicle road
speed and transmission gear
position. ARM is maintained for a
few seconds between shifts, then
deactivates if the shift is not
completed.
Old Dec 29, 2013 | 02:09 PM
gthal's Avatar
gthal
If you use the paddles to downshift, the car will blip the throttle to rev match. A6 owners have confirmed this even on the C6 as far as I can tell. If the A6 doesn't then it is the only high performance auto/DCT today that doesn't and would, therefore, not be a good transmission for track duty and a HUGE fail by GM... I'm confident GM didn't overlook this.
Here is a link to a discussion on it below... since '08 this has been a feature on Corvette autos. So, he wasn't joking and if "we all know the A6 does not have rev matching" then we might all be wrong
http://forums.corvetteforum.com/c7-g...nsmission.html
When the auto downshifts when using the paddles, it blips the throttle to allow the car to downshift more quickly while not unsettling the car. The reason we hear so much about this on the M7 is that it is new and rare for a manual car to do the same thing.
Old Dec 29, 2013 | 08:06 PM
dcbingaman's Avatar
dcbingaman
No joke. The A6 rev matches and shifts as fast as the M7. I have driven BOTH and own an A6. I would have no problem tracking my A6 Z51 and have no fear of getting out-shifted by a manual. It's that good. Anyone who says otherwise hasn't actually driven the C7 with the A6.
Old Dec 29, 2013 | 08:11 PM
9157's Avatar
9157
Naples FL
I agree. You have got to drive it to believe it.
Old Dec 29, 2013 | 08:18 PM
Guppies's Avatar
Guppies
St. Jude Donor '05-'06-'07-'14, '21
Sorry, but both my C6 and C7 are A6's and both bump the throttle when I down shift while in Manual.
Old Dec 29, 2013 | 08:23 PM
jkcam6017's Avatar
jkcam6017
Pot meet kettle.
To Transmission problem?
Old Dec 29, 2013 | 08:33 PM
senah's Avatar
senah
my advice: stay in touring mode until you have read the owner's manual.
Old Dec 29, 2013 | 11:18 PM
Cruiter's Avatar
Cruiter
On order: Torch Red Z51
No, some of us actually use it with the A6. When downshifting with the paddles it has the rev matching. Plus if you've been driving aggressively in the mountains in sport or track mode and move the selector from manual back to auto, hitting the brakes causes downshifting at pretty high RPM's as if you were doing it with the paddles. The more opportunity I get to play with this tranny, the more I like/love it .
Z51, A6, and mag ride.
Old Dec 30, 2013 | 07:42 AM
pgway's Avatar
pgway
WTF!
Where do people come up with this nonsense?
Only DCT automatic transmissions have rev matching!
The C7 does not have a DCT transmission!
The C7 A6 transmission has a Torque Converter!
Hello?
