Allocation question
Old Jan 25, 2014 | 04:46 PM
Larry/car's Avatar
Larry/car
Originally Posted by Highway 61
Yes, I realize that because I have three other vehicles hooked up with them right now, but I want it to show up on the window sticker and if I'm correct about this with the factory tender, I will only need stick the cord into the lighter socket. With a store bought tender, I would have to connect it at the battery, which means I would have to open the rear deck lid to plug in.
There are charge ends available from Deltran that plug into the lighter/power socket. Suggest; Battery Tender Jr., Mfg. Deltran.
Old Jan 25, 2014 | 05:06 PM
MikeK's Avatar
MikeK
Highway 61: Be aware that the only outlet that will charge 24/7 is the one in the trunk. The others shut down with the key off. You can but CTEK Multi US 3300 for $25-$40 w/cig adapter all over the web.
Old Jan 25, 2014 | 05:08 PM
Highway 61's Avatar
Highway 61
From: Between Forest Lake and White Bear Lake in the Land of 10,000+ lakes
Originally Posted by Larry/car
There are charge ends available from Deltran that plug into the . Suggest; Battery Tender Jr., Mfg. Deltran.
Yes I realize that, but if you don't order the factory tender, will there be the wire going from the battery to the lighter/power socket?
Old Jan 25, 2014 | 05:10 PM
Highway 61's Avatar
Highway 61
Well that sheds some light on things. Thanks.
slvr 07's Avatar
slvr 07
Default battery package
before i ask. let me apolagize for my spelling, then for my asking What is the battery package. thank you
Old Jan 25, 2014 | 05:36 PM
Patriot77's Avatar
Patriot77
Originally Posted by Glen e
congrats - except for the wheels , it looks like you will order my car:
Is that the "factory spoiler"???
Old Jan 25, 2014 | 05:47 PM
Glen e's Avatar
Glen e
The factory "wing" spoiler
Old Jan 25, 2014 | 05:50 PM
markk1's Avatar
markk1
Highway, whatever battery tender you use will provide charging current back to the battery through the same wires that power the socket from the battery. Just be sure to plug into the "unswitched" outlet in the trunk as was suggested earlier in the thread. The "switched" outlets elsewhere in the vehicle are disconnected when the ignition is shut off.
Old Jan 25, 2014 | 06:14 PM
GTFD2's Avatar
GTFD2
Wonder why it is shown as an $15 option then, if it's required the dealer give it to you in front plate required states?
Does the VKE front plate shown on your window sticker?
Does not show on my window sticker but both plate holders were in the trunk of the car when it was unloaded from the carrier. We were able to be at the dealer when the truck pulled in.
It is a $15 option for people who live in states that do not require front plates.
Old Jan 25, 2014 | 06:27 PM
Tannman's Avatar
Tannman
You can purchase the "lighter socket" adapter for about $6 to connect to an over the counter battery tender. Also, the only socket in the car that you can use to charge is the one in the cargo area. The socket in the cockpit area is wired through the ignition.
Old Jan 25, 2014 | 06:49 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Hey Glen, would you quit showing off already?!
Old Jan 25, 2014 | 06:52 PM
Glen e's Avatar
Glen e
Never! Fell free to set me on ignore....LOL
Old Jan 25, 2014 | 07:09 PM
  #33
Highway 61's Avatar
Highway 61
It's a battery tender to keep your battery charged up when you don't drive the car very much. If you drive your car at least once a week, you probably don't need it.
Old Jan 25, 2014 | 07:11 PM
  #34
Highway 61's Avatar
Highway 61
Thanks for clearing that up. Just saved $15 !
Old Jan 25, 2014 | 07:21 PM
  #35
Highway 61's Avatar
Highway 61
Sounds then like a store battery tender will work just as good.
I still want to get the factory tender so it shows up on the window sticker and I'll probably buy another store tender to use.
Old Jan 25, 2014 | 07:24 PM
  #36
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I still want to get the factory tender so it shows up on the window sticker......
Seriously?
Old Jan 25, 2014 | 07:26 PM
  #37
Highway 61's Avatar
Highway 61
Hey, no problem Glen! You should be proud.
To Allocation question
Old Jan 25, 2014 | 07:30 PM
  #38
Highway 61's Avatar
Highway 61
Originally Posted by KenHorse
Seriously?
Yes, because I don't expect to have more than 20K miles on this car after 20 years and it will still look like the day it was new.
Old Jan 25, 2014 | 07:34 PM
  #39
green2000's Avatar
green2000
I plug my Battery Tender into the lighter socket and run the cord out to get AC power. You will need to do that with the $100 factory option. You still need to connect to AC somehow.
Old Jan 25, 2014 | 07:36 PM
  #40
KenHorse's Avatar
KenHorse
And having the tender listed on the window sticker will aide you exactly how????
