Battery access
Old May 5, 2014 | 11:32 PM
Highway 61's Avatar
Highway 61
From: Between Forest Lake and White Bear Lake in the Land of 10,000+ lakes
Originally Posted by Jim Barker
Decided to see if my 100 dollar trickle charger works, after 5 hours it still had not topped off the battery.
I just picked up my car and plugged in the factory tender the second day. It stayed on the charge mode for at least 6 hours before I went to bed. The next morning it was on a maintainer charge mode so I don't know how many hours it took to fully charge the battery.
Old May 5, 2014 | 11:34 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by Glen e
just yank on the carpet, it comes loose. get a piug for the ext power plug off amazon and plug your charger into that...easy when you sit down and think it out...
The trick is to remove the bottom of the wheel well cover. It pops off with a few clips. No need to remove it or the upper attachments, just the bottom. It helps get the carpet out withoiut ripping! It's very important when you need to remove more to get at the rear fuse panel.
Old May 5, 2014 | 11:48 PM
Rossi6998's Avatar
Rossi6998
