Non-NPP to NPP Exhaust
Question, I ordered my C7 without NPP exhaust as I am going to an Akrapovic as soon as they come out. However, Akra telling me they are 6 months out, I cant deal with a stock exhaust sound for much longer. So, a friend of mine took off his NPP and will give it to me but, I'm not sure if the wiring and/or plumbing is on my car, considering it was ordered without? Does anyone know if I did install the NPP is it plug and play or is their additional wiring/plumbing that needs to be done as well? If so, it's probably not worth the trouble.
Advice needed from the experts, please...
It's a huge PITA.....nothing like the C6.
Read this then head over to the C7 Tech Forum and talk to these guys. I don't know if it's been solved yet:
https://www.corvetteforum.com/forums...-npp-help.html
The NPP exhaust is not plug and play as far as being able to adjust the sound from inside the car.
You can install the exhaust and the valves just stay open thus giving you a throatier sound.
This wasn't easily accomplished on the C6 and the complexity of the C7 control strategy for the NPP exhaust is ten times more complicated than on the C6.
If your car didn't come from the factory with NPP, the best you can currently do is to install the exhaust and it will leave the valves open all the time making your exhaust louder and more aggressive sounding than stock non-NPP.
You are missing the wiring harness to provide system power to actuate the valves (no longer vacuum actuated). You are missing all of the software calibrations to trigger the operation of the valves in their different modes for each of the driver mode selections.
Thanks everyone... Quite frankly, I'm ok with leaving them open. As I understand it, my friends NPP exhaust was cut to accept his Corsa exhaust. So, I'm assuming there would need to be some pipe added? Just wondering if worth the hassle for 6 months of painful, annoying and emasculating Oldsmobile sounding car? Thoughts from all are welcome... Thank you
Oh crap - I'm sorry.... No offense but just wanted to; oh never mind, anything more I would say would just get me into deeper water... You are all so helpful and don't need any enemies... Sorry again Talon90
I also have the non-NPP exhaust. The car has a nice sound, but not nearly loud enough.
I would love to switch to either B&B PRT or Flowmaster, but there are issues with people throwing CELs.
The NPP could be an option, I wouldn't really care if it is open all the time.
Is welding required or would it just be unclamp the stock mufflers and clamp on the NPPs?
After I get out of this, the C7 definitely seems quiet(click on small pic to hear it).....
Ignore the wheels, this was when I first got the car before I got new Center caps and lugs and cleaned the car up.
They look better now...
I'm Batman..
Pro Mechanic
I like my stock exhaust. When you apply power the stock system sounds ok. There is a resounding residence that occurs at rapidly applied partial power that sounds neat. This sound is further enhanced when more power is smoothly applied. We never hear much about the stock system, most here never heard it or have written it off as anemic. Doesn't sound at all like my 1961 Oldsmobile.
