SD card question/memory question
What size sd card do we use for the PDR? An 8 GB is only 20 minutes? A 16 GB is 40 min. and cost about $40? Sounds kinda expensive.
Also I can't get the memory settings to work for the seats/steering wheel for entering or exiting. They should work when the door opens or closes? Help! Thanks
I asked the same question an earlier post. The response I got was 32GB.
As far as the seats go, do the exit is easy. Go to you entertainment screen and hit settings, vehicle. You options will be under comfort.
I still can not get the seat to go into the correct driver position when I enter the car. I was told by the dealer today that this option for this is no longer available. Not really sure if that's right or not but I will wait for someone else to respond.
That is what mine showed remaining when I first put the card in.
Seats are another matter. Is your car auto or manual?
Here's the official capacities:
Finally, the system features a dedicated SD-card slot in the glove box for recording and transferring video and vehicle data. Recording time depends on the capacity of the memory card, but an 8GB card can record approximately 200 minutes, while a 32GB card stores up to about 800 minutes - more than 13 hours of driving time.
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
A 32GB SD card will hold in excess of 11 hours of video.
On the memory. Have you programmed your entry and exit positions to memory locations (buttons on the door)? Have you gone in to the personalization settings and set up auto entry recall and auto exit recall?
I only used the buttons on the door.
Ignore the Best Buy chart. How long you can record on a given SD card size depends on what the resolution and frame rate are. The times I posted are based on the actual PDR specs.
NCM Ambassador
You need to go in to your personalization settings. Once you have programmed the buttons on the door to the positions you are comfortable with, go to the main menu on the center display screen and scroll down and select Vehicle. From the vehicle settings scroll to and select Comfort and Convenience. You will need to make selections in:
Auto Memory Recall (press it and choose between On Driver Door Open or On At Ignition.
Easy Exit Options (press it and select On.) - > Do not set your exit position so that it is all the way so your seatback is against the rear bulkhead. Move it in about a 1/4" to prevent it from triggering the limit sensors.
SanDisk Utra 32 GB SD Card $16.99 on Amazon.
Amazon.com: SanDisk Ultra 32GB SDHC Class 10/UHS-1 Flash Memory Card Speed Up To 30MB/s, Frustration-Free Packaging- SDSDU-032G-AFFP (Label May Change) [Old Version]: Electronics
When I started out in computer sales, I sold a college a 16 KB (yes KB!!!!!!!) upgrade to their minicomputer for a little over $10K. They tripped over themselves thanking me for supporting their school.
Oops...I have dated myself!
Sorry, but I think Chevy knows more about what it's camera can store on a given size SD card than Best Buy does. BB is probably using full 1080p HD video as the benchmark for their figures.
Totally dependent on resolution. Wouldn't surprise me if they were using 4k as their benchmark. My phone can record 1080p and 4k resolution videos and I have tons of storage left.
I read other comments where we may not want the seat all the way back against the stops at exit the way I have mine set. I will be calling you early in the afternoon if I can't get it to work.
First Z06.
