Ouch
Old Nov 2, 2014 | 06:56 PM
newbie2vette's Avatar
newbie2vette
Default Ouch
I decided to "De Badge" the rear end and remove the "Corvette" letters, as I was attempting to remove the left over sticky stuff, small part of the paint came up. Is touch paint available yet? The rear end looks better without the corvette lettering, now I need to touch up a small area.
Old Nov 2, 2014 | 06:58 PM
Glen e's Avatar
Glen e
that's why I tell everyone to let the goo gone dwell for 30 minutes, the badge literally falls off and all the adhesive....
touch up paint at automotivetouchup.com
Old Nov 2, 2014 | 07:02 PM
Zymurgy's Avatar
Zymurgy
Moderator
Artic white is WA-9567
Old Nov 2, 2014 | 07:08 PM
newbie2vette
Thank you.
Old Nov 2, 2014 | 09:03 PM
mpuzach's Avatar
mpuzach
Originally Posted by newbie2vette
...The rear end looks better without the corvette lettering...
Not that anyone else's opinion should matter, but I strongly disagree.
Old Nov 2, 2014 | 09:19 PM
buckeye4's Avatar
buckeye4
I agree with your disagree.
Old Nov 2, 2014 | 09:24 PM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
I do too.
Old Nov 2, 2014 | 09:28 PM
5150 BRD's Avatar
5150 BRD
Old Nov 2, 2014 | 09:42 PM
TKay's Avatar
TKay
I hate apathy, but I feel strongly both ways
Old Nov 2, 2014 | 09:46 PM
owc6's Avatar
owc6
Are you sure?
Old Nov 2, 2014 | 09:50 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Good luck with the touch up
Old Nov 2, 2014 | 09:52 PM
pittperson's Avatar
pittperson
I disagree with your agree of his disagree.
Old Nov 2, 2014 | 10:09 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Did you yank on the letter? I would think you would need to pull pretty hard to pull up paint on a newer car like that.
Whatever the cause, I hope the touchup is clean and unnoticeable.
Old Nov 2, 2014 | 10:38 PM
hawkgfr's Avatar
hawkgfr
It won't be...
Time to fall in love with a new letters to cover it up...
Old Nov 2, 2014 | 11:09 PM
But to the OP, sucks that the paint was damaged.
Old Nov 2, 2014 | 11:10 PM
arcticZ51's Avatar
arcticZ51
I just de-badged the Corvette lettering myself today (also arctic white). You just have to be careful pulling on any of the letters. It can hinge and the opposite corner can gouge into the paint.
I did a hair dryer and flat nylon dental floss, sawed right through it. The bigger job is removing the black foam/adhesive. About 15 minutes with Wd40 and a healthy dose of elbow grease I was finally able the clear it all. Hopefully I didn't swirl up the paint in the area with all the rubbing. It's hard to see on Arctic White, if I damaged the clear.
Old Nov 3, 2014 | 06:42 AM
newbie2vette
Originally Posted by hawkgfr
It won't be...
I hear yeah, I have a plan to do just that.
To Ouch
Old Nov 3, 2014 | 01:16 PM
SteveSoCal's Avatar
SteveSoCal
Originally Posted by owc6
Are you sure?
What's the difference between ignorance and apathy?
I don't know, and I don't care.
Old Nov 3, 2014 | 06:56 PM
newbie2vette
Working on the final touches for the reason why I wanted to "De-Badge", this is along with cleaning up the side of the car. I reveal tomorrow, the final result will appear as if nothing never happened.
Old Nov 3, 2014 | 09:05 PM
Larry/car's Avatar
Larry/car
The Corvette letters don't seem to fit below the C7 wings. The ones that I have seen removed don't look right either. I am letting mine as it came from the factory.
