C7 Track Capable
Day thee of the level one course is 'open lapping'. Drive a fast as you feel capable (Performance Drive Mode in Track level 1) in 20 to 30 minute sessions, passing allowed on back and front streights... in the desert heat, with AC 'on', and the car never overheated, brakes never faded, oil and trans temps stayed at 'aceptable levels' and tire temp indicators showed 'Hot'... never on my street C7 did my tire temp ever show anyting more than 'warm' - - even in extend summer highway cruising.
We pushed these cars hard--- not a single failure. In my opinion, the Z51, with GM Track Spec Prep, on OEM Run Flats, is 'track ready'. Even the few A6 autos (2015 cars were present, but did not yet have 1,500 street miles on them so no A8s were avaialable) ran all day without over temperature issues (I was in a 7 speed, but would have liked to try one of the A8s if it were available). Don't know if it was the drivers or the transmission, but the 7 speed manuals were noticably faster around the track than the A6s.
If you haven't been - the best 'enhancement' you can make to your C7 is learning how to dirve it!
Save the wave! Al
One of these days! Sounds like you had fun. Any photos of the drive?
My wife and I Did the level one this Oct, the 15's were just coming in, but not in use. Day three was great.
We will be going back. Make me love this car even more.
ECR is a 2.5 mile track with straightaways and challenging curves. Driving requires lots of accelerating and braking. The transmission was shifting frequently. I was taking it easy. With the stock brake pads I was hesitant to go very deep into the turns.
The car's performance was spectacular. I used track mode with full traction control. I have run a C5 and C6 on this track. The C7 was that much better.
However, track ready? No. The brakes were fading after a few minutes. This is the same as my previous cars. I think it was all brake pad heating. I don't believe the fluid boiled.
The biggest concern was the transmission temperature. I was on the track for about 30 minutes per heat. By 20 minutes into a run, the transmission temperature was at 275+ F. This is much harder to read on the C7 compared to the digital DIC on the C6. I slowed down and held it there for the rest of the heat. The other fluid temperatures seemed OK but I really didn't have much opportunity to watch them.
This weekend I am installing CaboTech AP10's and AP8's brake pads. I am changing to a DOT4 brake fluid and adding speed bleeders. I will probably try the wheel rings on the next track day.
The transmission over heat still has me bothered. On the C5 and C6 I added third party transmission coolers (both automatics). The temperature still went up but I was well under the limits at the track even on a 95 degree Texas day. I don't see any way to add a cooler to the C7. I looked at adding an air scoop to divert more cooling air down the duct, but I can't model a situation that shows that will do much good. Right now it looks like my track days are going to be on cool days only and probably limited to 20 minutes per heat.
When I came home, the seat belts came out, stuff went back in the trunk and it turned back into the most spectacular street car I have ever owned. Wife loves it and loves to drive it. But not near a track.
However it is not a track ready car.
Talk to LG Motorsports. They have a package that includes a redesigned/bigger pan and cooler for the C7. Lou has tested their A6 on-track with trans temps well under control.
S.
Just food for thought.
S.
