Installing CB cable
Old Oct 18, 2016 | 02:18 PM
  #61
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Originally Posted by eboggs_jkvl
Uses batteries. Batteries seem to go belly-up at the most inopportune times. That's why I installed the radio. I communicate to the other cars in the Caravan quite well, for long periods of time, with great range and clarity. I usually ride mid caravan or I can do tail-end charlie to keep track of the caravan continuity on long cruises. If need be, I use 5, 10 or 40 watts of power. 5 seems adequate for most rides.
Do not want another hand held walkie talkie ever again!
Elmer
Your internal antenna installation bothers me for 2 reasons:
1) Being inverted, the main lobe (pattern) of the antenna is below the horizontal instead of above it
2) RF field exposure questions
Old Oct 18, 2016 | 05:59 PM
  #62
Mike Mercury's Avatar
Mike Mercury
when running no more than 5 watts... and using a handheld antenna, the RF exposure is no more than a handheld would be. Never go above 5x TX and you'll be fine.
I've run my particular setup in multiple Corvettes; worked fine for years & years. True, no better performance than a handheld... but I didn't want the hassle of a handheld either.
Old Oct 18, 2016 | 06:08 PM
  #63
felkebg's Avatar
felkebg
.._. .._ _. _. _.__!
Old Oct 18, 2016 | 07:58 PM
  #64
KenHorse's Avatar
KenHorse
_.. .. _.. _. _ _ _ _ . ..._ . _. _._. . _. ... _ _ _ ._.
