A8 supercharged
If you plan to keep the car long term I would read up on what changes went into the Z06 to produce a engine they felt would provide long term reliability and be warrantable. Pretty eye opening!
I think people are too scared of nitrous for no reason, it's not any harder on an engine or more risky than a blower or turbo (in almost all cases it is safer) and you maintain all the driveabilty of stock while having the power on tap if you so desire.
Re nitrous, none other than John Lingenfelter didn’t recommend it saying that it had more potential for serious engine damage than most other power adders. Hard to disregard someone with his background. Don
All power adders increase cylinder pressure by increasing volumetric efficiency (actually over 100%) and the amount of available oxygen for the engine to burn with fuel. All power adders that use compressed air have increased IAT (intake air temperatures), so essentially the air being let past the valve into the combustion chamber is hotter than the ambient air being pulled through the air filter (and also hotter than the air would be from simply running through the intake manifold and cylinder head). Increased IAT's will cause detonation sooner than cooler IAT's all else being equal. Detonation is the #1 risk to cause engine damage with a forced induction application.
A fundamental difference with nitrous from compressed air power adders (all supercharger and turbos) is that it actually lowers IAT's, the nitrous is very cold as it exits the bottle. It doesn't lower them a ton but the fact that they are less than ambient and wayy less than a blower/turbo is a huge deal. It also means that nitrous powered cars are not as effected by weather conditions as N/A or turbo/blower cars.
Another difference with nitrous from turbos and blowers is that it's not "always on". I understand that superchargers have a bypass valve and turbos have a wastegate but in reality the power is always available, as soon as you roll into the throttle the car can start making a few psi of boost even with part throttle driving. As stated above that is putting more stress on the engine every time you make even a little bit of boost. Nitrous doesn't do that, you can drive around 99% of the time with no extra stress on the engine and only turn it on when you are ready to get busy.
Nitrous kits are also WAYYY cheaper than supercharger kits. The best of the best nitrous kits are about $2k with every needed option/accessory. The lower end kits are under 1000 bucks, they are also way less labor intensive to install and require no permanent modifications to the car. My Kenne Bell kit took me over 30 hours to install on my 2012 Mustang (being a perfectionist) and I had to cut a huge hole for the air intake in my car, among other permanent modifications to vacuum and PCV hoses. Nitrous kits also add a lot less weight to the car, and don't add all of it over the nose. A typical supercharger kit with intercooler etc is about 100 lbs right on the nose of the car. A nitrous bottle is 25lbs full and goes in the trunk (and is also easily removed if you don't need it), the rest of the kit is maybe a few lbs on the front end.
The two main downsides to nitrous are the fact that you have to keep filling the bottle, and it's easy to get carried away with (which may have been the reason for Lingenfelter's comment). On a 125 shot I could get 6 full 1/4 mile passes at the drag strip out of one bottle (still had some left just the pressure would drop and it wouldn't be as effective). If I had installed a NANO kit I could have gotten even more. My local shop charged $40 to fill the bottle, but if I had invested in about $200 worth of equipment and bought it 90 lbs at a time (and used a mother bottle to fill my 10lb bottle) I could have gotten it for half the price. Even horsing around on the street there's no way I would use more than 2 bottles a month, so you can see that at $80/month it would take a long long time to even match the price of a supercharger kit with installation. It's easy to change the jets and go for more and more which for people without good self control can be a bad thing.
I didn't mean to derail this thread to be about nitrous, I was just addressing your comment and maybe enlightening some people that are scared of it for no reason.
If I learned anything from the LS7:
I'm waiting to see how the new LT1 holds up over the long run and until warranty runs out.
The oil issue that can be there for the Z51 was disheartening at best.
Don't want or a catch can or fumes.
Cenrti's can be great though.
Thank you for adding your information to this thread. It is a consideration. Lead time?
Our conversions take about 2 weeks with scheduling. We're booked into May right now, but would work to move stuff around if possible. Please drop us a note if interested: info@callawaycars.com
Thank you -
Thank you -
If you plan on selling the car in a year or two I would highly suggest you don't do it because you'll just be flushing money down the toilet. If you plan on keeping the car for a long time and it's something you want to do and can afford, then I say go for it
Drivability in NOT affected in the least. Might want to read this thread and how reliable a properly installed supercharger can be:
https://www.corvetteforum.com/forums...lity-list.html
Thank you -
Seems like there are so many options. So many toys!
