A8 Software Update
I have an appointment to have the PI1473 A8 software update done on Friday, but after scheduling it I started to read the procedures to complete the update. After performing the update the tech must complete a "fast learn procedure," which includes the following requirement using the scan tool:
I can tell you that I won'd let a tech take my car out unsupervised and drive it 20 miles (or whatever) to get the temperature up to spec. If they do the update the car will likely sit for an hour or more to complete, so the tranny temp will certainly be out of spec at the time the fast-learn procedure is needed. So do I suggest to the service manager that I take it out and try to get the temp above 167°, then bring it back to the dealership? Assuming I do the driving what's a good method to get the temp to spec? Take it out on the interstate and run it hard until it gets within the required window? What would you do?
I've played around with the tranny-temp pocket gauge for short periods and never noticed it getting very high. I just took an 11-mile ride in rush-hour traffic and 95° ambient, and the tranny temp barely hit 150°.
My 2015 built Aug 21 2014 has that problem with no change at 9,000 miles now. I have hesitated to take it to the dealer so would really appreciate a post on how you make out ....good luck, and tks, Doug
I never had a harsh shift, except downshifting (2>1 or 3>1) at slow speeds. This happened twice early on and never repeated, but even then wasn't as big a deal as some others have described. It does flare with a sluggish shift on that first cold shift of the day, however, and that hasn't abated. The most worrisome issue is that on four occasions, three times in two days in May and once since then, on the first cold shift from "P" to "R" reverse will not engage. Instead, the "R" on the DIC blinks (~2X/sec) and will engage when I shift to "D" and then back to "R". On one occasion it engaged after about five seconds (did not time it). I've only heard of a few others who've had this glitch, but those owners claim the SW update fixed that issue.
I have the A8
