Quick question for NPP C7
Old Jan 18, 2016 | 03:42 PM
meyerweb's Avatar
meyerweb
Originally Posted by cello002
I'm confused, why you cannot drive in D for any length of time w/o CEL on? You mean if I install Corsa on NPP corvette, I can't drive in D?
There are two sets of valves on a car with NPP exhaust. The ones behind the mufflers we refer to as the NPP valves. The ones in front of the mufflers we call AFM valves. The difference is important.
If you replace the mufflers, and leave the AFM valves in place, then you'll have no problems. The car's electronics don't care if the NPP (behind the muffler) valves are working or not.
But if you replace the exhaust system with one that eliminates the AFM valves, the car will notice that those valves are working and display a Check Engine Light (CEL) code on the dash. The poster you quoted says that leaving the transmission in manual mode will prevent the CEL from coming on, but if you put the transmission in D you will eventually get the CEL.
The CEL won't hurt anything, but if another problem occurs you won't know about it, because the CEL is already on.
The solution, it seems, is to leave the AFM valves connected, even though they don't actually do anything any more. Then you won't have the problem of a CEL.
