Magnetic ride
Old Feb 1, 2016 | 08:38 PM
ejw71's Avatar
ejw71
Default Magnetic ride
Can it be determined from my C7's VIN (1GYM2D72E5118614) is it has magnetic ride? Thanks, Ed
Popular Reply
Feb 1, 2016, 08:54 PM
RicK T's Avatar
RicK T
No, suspension info isn't in the VIN.
Of course on a 2014, you have to have Z51 first before you can have Mag Ride.
Two visual ways to check. Look through a rear wheel at the shock. If it's yellow, it isn't Mag Ride. If it's black, it is. Or, open the hood and see if there is a black wire coming off the top of the driver's side shock. If it's there, it's Mag Ride.
Old Feb 1, 2016 | 08:54 PM
RicK T's Avatar
RicK T
Old Feb 1, 2016 | 10:25 PM
rcooper's Avatar
rcooper
St. Jude Donor '15
That is on a '14 or a '15. Mag ride was not a stand alone option on the C7 until the '16 was introduced.
Old Feb 1, 2016 | 11:31 PM
sdurg24's Avatar
sdurg24
Send away for a window sticker for the car from National Corvette Museum and it will list all options.
Old Feb 2, 2016 | 04:58 AM
mapman's Avatar
mapman
The RPO codes are on a paper tag afixed to the cover above the battery.
Raise the cover over the battery up (like you were going to change the battery) and you will find the RPO tag.
Old Feb 2, 2016 | 12:58 PM
felipegn91's Avatar
felipegn91
Banned Scam/Spammer
So all C7 16' have mag ride ?
Old Feb 2, 2016 | 01:04 PM
kp's Avatar
kp
It is an option on the non-Z51 and Z51 for 2016.
2014 and 2015 mag ride was an option only on the Z51.
You can buy a non-Z51 or Z51 without mag ride in 2016.
Old Feb 2, 2016 | 05:16 PM
3X2's Avatar
3X2
Ask your dealer to run your vin to check for options. BTW, the vin you posted is only 16 digits, not the needed 17.
Old Feb 2, 2016 | 07:50 PM
lakemg's Avatar
lakemg
What year is your car and is it a Z51? This will help narrow things down...
Old Feb 2, 2016 | 08:14 PM
mpuzach's Avatar
mpuzach
If you post your complete VIN I can help you. One digit is missing.
Old Feb 2, 2016 | 09:00 PM
AUTO_X_AL's Avatar
AUTO_X_AL
I can get an invoice as well. Missing either another y or an x
Old Feb 3, 2016 | 09:16 AM
bjones7131's Avatar
bjones7131
Educate me, what does the mag ride do for you?
Old Feb 3, 2016 | 12:42 PM
AUTO_X_AL's Avatar
AUTO_X_AL
Simply put, the oil in the shocks have metallic particles in them. When you run current thru them, it excites the electrons and they expand. Upon expansion, the viscosity of the oil changes depending upon the current. This lets you control the how the shocks act because you're in control of the fluid and how it passes thru the valving in the shock. You can soften or stiffen the shocks within a rather wide range.
The long and the short of it is that you can make it stiffer and softer as you need to and tie it into a program. The cars are pre-programmed so you just switch the drive mode and a new shock profile is enacted for touring, sport, and track.
It also allows for a softer spring in the cars as well. You can compensate for spring rate with the shocks. That's why most people say they ride better. Its not because of the shock its because the shock allows you to use softer spring without sacrificing performance. It also has the PTM which allows for varying degrees of traction control and help.
I'm not an engineer and am open to be corrected but this is my understanding of how the system works.
Old Feb 3, 2016 | 02:35 PM
speedlink's Avatar
speedlink
I think that is a very good explanation.
Old Feb 3, 2016 | 02:44 PM
RicK T's Avatar
RicK T
This is possibly the best tech article on F55. It was written by member Hib Halverson in 2003 when the the 1st gen F55 was released in the C5. So keep in mind that the C7 is operating with the gen 3 version of the system, much improved but the basics are the same.
Bottom line, it isn't about a hard or soft ride, it's about wheel control.
http://www.corvetteactioncenter.com/...h-car-444.html
Old Feb 3, 2016 | 11:19 PM
bjones7131's Avatar
bjones7131
Very good explanation, thanks
Old Mar 2, 2016 | 04:09 PM
Maxpowers's Avatar
Maxpowers
I have a question. My car isn't built yet but I ordered Mag Ride. Can I have the suspension soft but the rest of the car in Track Mode (for the louder exhaust, tighter suspension etc.)?
I would consider configuring this way for daily commuting on the rougher roads. Thx
EDIT: I continued to search and according to this thread Mag Ride is directly linked to drive mode and can't be over-ridden. It would be great if someone else could confirm. Thx
https://www.corvetteforum.com/forums...ng-mode-2.html
To Magnetic ride
Old Mar 2, 2016 | 04:19 PM
plasboy's Avatar
plasboy
You can control exhaust and steering feel separately on the DIC. Suspension firmness is set on the mode **** for track tour etc. Can be in tour for soft ride and have exhaust set to track independently.
Old Mar 2, 2016 | 04:45 PM
Maxpowers's Avatar
Maxpowers
Thanks!! This is great to hear.
Old Mar 2, 2016 | 05:09 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
let me add, with mag ride there is way more difference among the driving modes than in the past. And, what is really great about it is if you live in an area where your roads vary from super smooth to greatly in need of repair, you will learn to work the mode **** for comfort on the bad roads; and utilize track mode, if you like, on the smooth roads. The Corvette with mag ride is essentially several cars in one. It's a lot of fun to compare the differences in road feel. Personally, I would not order a vette without it.
