C7 - 2 problems
- Brakes squeak
Dealer Maintenance said, "Yeah we get that a lot. Sorry, there's no fiX for that."
So I have to drive a brand new car with squeaky brakes that can't be fixed - un****ing believable!
- Driver seat will dislocate your hip
Driver seat OK for short rides around town but after a while you will notice how uncomfortable you are.
The side bolsters are too high and too stiff and too close together.
Your femur bone is forced into unnatural angle wrt hip socket and eventually you have pain in legs and in hips.
However this is fixable. I had seat repair specialist remove seat and then cut out the offensive bolster padding- ~$200. Now comfortable like all other cars in the world.
- Also no spare - Ok around town but what do you do if you get a flat half way between LA and Vegas(230 miles)?
- Brakes squeak
So I have to drive a brand new car with squeaky brakes that can't be fixed - un****ing believable! Good luck with this one... mIne do not squeek so I cannot comment.
Sounds like you solved the problem.
Edited to add:
My brakes have never squealed. If they did and GM wouldn't help, I'd talk to a brake shop. Squealing brakes can be fixed even if you have to change pads. Don't let something that simple sour your Corvette experience.
A flat tire is only one of the many things that can go wrong with a car on a long stretch of empty road. Quite a few people will find it impossible to remove a wheel either from corrosion buildup from the wheel to the hub or from a mechanic who was overly enthusiastic with the impact wrench.
My Z06 has competition seats and I drove it back from the museum, ~370 miles, with only a short stop for fuel and I found the seats to be as comfortable as those in my Cadillac for long trips. I would not hesitate to take the Z06 for one of my one day (800 mile) trips to the MS gulf coast.
My brakes sometimes squeak on the first exit from the garage after not being driven for a few days but it isn't a problem on the road. There are different pads/compounds that can be selected for less noise and less brake dust but performance brake pads are not going to be the quietest type around.
- Brakes squeak
As for the seats, sounds like "your" body is having a problem, not the seats. The bolsters on mine adjust so I don't have the problem you described
Yes, there is no spare. What, you didn't know that before you bought the car?
As a side note, where would you suggest they put a spare
- Brakes squeak
I get that (in my 14): only in certain weather conditions, only in reverse (like backing out of my driveway). IIRC, There was a TSB on it, something about adding (copper based?) anti squeal past on the pad shims, or something like that. Not guaranteed to work.
Seat discomfort:
Try taking your wallet out of your back pocket.
That will change the angle in which you are in the seat, and likely make it much more comfortable, as your left/right hip joints will be more or less even, instead of the wallet side being higher.
Tires are run flats. IIRC, spec'ed up to 200 miles up to 50-mph with no pressure.
- Brakes squeak
