I have the non-painted GM ones on mine and like them as is. Very subtle addition...
I have these also. Like that they are barely noticeable, and they must be better than nothing. Easy to install. I went to Harbor, bought a cheap set of trim tools, and have the new ones on in ten minutes.
And, I bought them from Gene. They have the front, and back at the best price I found. Thanks Gene.
Originally Posted by Gene Culley
We would certainly be happy to help you out with new GM. You can order at the link below.
I was hoping the GM splash guards would do as you wish. In fact after 2 1/2 years can say the rears do. However it took only a few weeks to see the front ones did not. Suggest you look at where GM put that heavy plastic and you'll see the problem area, from the middle of the doors back up the side of the rear wheel well!
I was still getting pebble marks being thrown up from the sticky tires. Bought side skirts. Great solution and I was able to remove the marked up and discolored GM heavy plastic. Rocker panels still look new.
So it sounds like maybe a combination of the splash guards and the rocker panel is in order, eh? Since my couple is DSOM, perhaps the orange or the black rocker panels are an option. Admittedly, I've never seen the panels that match the color of the car - all have been black. Do you recall what those things cost? Also, would it look strange to have the rocker panels and NOT have the piece that is in the front of the car (ground effect looking 'thingy')?
...And those chips appeared to be only in the plastic itself. These cars all had about 10 to 20 K on them. Is there something to this in regard to body style difference between a Z51 and a base model?.
Yes. The base model has harder tires than the Z51 model, therefore stones do not stick to the non-Z51 tires as much. The Z51 tires are softer and stickier, more stones stick to them and get slung onto the body panels when driven.
thanks in advance!
Yep, afraid you'll need side skirts for the C7. After having "dings" on my '88 and '93 Vette behind the rear wheels when I ordered my '08 C6, before it arrived I bought contoured "splash guards" painted the color of the car. They integrated pretty well with the C6 but none I have seen do that with the C7. It fact with the way the rocker panels are tucked in, don't believe any reasonable width would work. Look for "side skirts" by searching the forum or google Stingray "side skirts" (not rocker panels!)
The "piece in the front" is called a splitter. Same concept as used in NASCAR etc. I got my side skirts to match my OEM Carbon Fiber roof and they were functional. Since I don't track the car, or go 125 mph very often the splitter is purely cosmetic. Didn't think I needed it- but finally added a carbon fiber splitter. Then that chrome bar in the grill looked out of place so added a real carbon fiber cover for it. With all that carbon fiber also added a carbon fiber hood vent! Those last 3 items are only for looks!
Thank you for your business and for the forum mention.
