C7 A/C not cold enough?
Let me know what your dealership says, thanks!
The C7's have a great deal of hot air flow over the hood and under the hood. The cabin air intake is sucked air from the cowl under the rear of the hood. So when the outside temp is high, I find the AC works great if I set the ac-mode to recirculate. This does not suck in hot outside air which is too hot to cold down. It sucks air from under the dash which is cooled and then makes it cold coming out of the dash vents. Try it, you will see the difference. My previous C5, and 2 C6's didn't need to use recycle mode.
These are just the AC and coolant line in the tunnel. Not as simple as checking for small leaks in a FE car with Condenser, Compressor and Evaporator close to each other in the engine compartment.
I have noticed while driving around, stopped or moving doesn't matter, the air coming out of the vents becomes noticeably warmer, but not hot and only for a minute or two, then goes back to good and cold. With leaks or part failures, we wouldn't have intermittent cold air, just hot. Now, I never use the ECO mode, as I'm sure 99% of us don't, so i can't explain why it would be engaging or moving the reduction coil in any amount while in normal "power" mode unless it's happening under WOT, and it's also very possible that there is a duct actuator not acting right. I've noticed every time I start it in the morning or a longer period of sitting, I can hear and feel the actuators rotating from their min and max positions( the way the HVAC module determines their zero and 100 positions) and this is annoying me because the control modules used to only do this if they were unsure of the actuator's position, under normal operation they shouldn't be doing position sweeps. At least that's the way they used to operate. Doing more digging and looking for a possible bulletin of some sort that might address it, but you're not going crazy, there is something weird happening. The connector on the back of the compressor circled in red is the thing I'm concerned with
