DIY wide body conversion project
JV
http://www.customcorvetteaccessories...erspoiler.html
JV
JV
JV
JV
JV
JV
Additionally, it looks like paint match is very good for panel painting, rare with a metallic grey.
Lastly, to the poster who expressed surprised at the dust boots. On our racecar we run OEM stock calipers and just remove the boots from brand new calipers when we're putting new ones on. They simply will not hold up to track/race use and melt and cause more of a mess than they're worth. High performance race calipers don't come with them to begin with and you're expected to rebuilt the caliper (swap seals) more frequently.
Don't know if you've seen this thread:
https://www.corvetteforum.com/forums...p-to-oops.html
It shows the aperture that a body shop took off and it doesn't seem there is much glue left. I wonder if the newer cars have reference points that the older ones didn't, that would make it easier for this part to be reinstalled. Hopefully, the poster will have more pics.
It looks like they also removed the door and left the hinges in place. Don't know if that would make any difference or be easier or not.
I just found it interesting compared to your project.
I'm really getting frustrated now, the delay in getting the last few parts is killing me. In the mean time I transferred the rear bumper wiring harness and installed the new fuel door. The fuel door came primed only, and I covered it with 3M carbon fiber adhesive wrap. I can always paint it later if I change my mind.
JV
Here is the L brace under the Right panel.
In this view I'm just holding the S bracket up next to the lip of the quarter panel to show that it covers the L brace screws, so they have to be put on in the correct order...
Everything in place and tightened on the passenger side...
Here is the L brace on the drivers side:
And the drivers side all set to proceed with mounting the rear bumper cover:
Here is the rear bumper cover clipped in place with all electrical connections back on the wiring harness for a test. No other screws/bolts have been attached yet, as this is a test fit and electrical connectivity test. There are several areas where adjustments can be made to the fit and panel gaps. The inner attaching bolt of the L brace is in a slot so it can be moved inward or outward as needed. Also the S bracket can be loosened and moved very slightly fore and aft. Shims can also be placed almost anywhere to adjust the fit.
All electrical connections checked out, including lights, deck release button and key lock.
NOW, Does anyone know how the Z06 rear brake cooling ducts fit and function. This first picture is the oem bottom-feed cooling duct from the Z51 which I have left in place so far. The next pictures are the Z06 ducts which are supposed to feed from the chin scoops in the lower panels behind the doors. But for the life of me I can't figure out how they are supposed to mount or where they would direct that air. I tried every imaginable orientation but they don't even come close to fitting anywhere near the back of the scoops. The exploded parts drawings I can find are of no help whatsoever. If anyone has any info on how these go on, please chime in. I know I can just continue to use the old Z51 ducts, but that leaves all the wiring and other modules visible through the duct opening, which looks ridiculous. Thanks for any input.
JV
The first one gets a screw from the bottom and one in from the back. Other one is a screw and a push pin I think.
