Convertible top problems.
Old Oct 20, 2021 | 09:54 PM
  #41
midlifetoy1's Avatar
midlifetoy1
Ouch!!!
Old Jul 24, 2024 | 04:32 PM
  #42
cubelets's Avatar
cubelets
6th Gear
Just adding to this string late. Periodically I use the 303 brand fabric sealant on my black convertible top. While prepping to spray I always cycle the convertible top up a bit and slide a tarp under the front and then the back to keep the spray off my glass (which is hard to clean after since it repels water). After years of doing this I recently got distracted and left the tarp in the rear section and closed the convertible top and it closed fine, at least I thought it did. After a few minutes I noticed the tarp stuck and I reopened the top. As it reopened enough for me to remove the tarp I then continued to close the top and got this overheat message discussed in the thread, and the top barely got back to full position but did not lock in place . I let the car rest about 15 minutes then I raised and lowered the windows (it let me do it surprisingly) and voila it worked fine and hasn’t had an issue since. BTW the 303 spray about 2X a year does wonders, it holds and protects the color extremely well.
