Trickle charge issues
Old Nov 4, 2016 | 11:44 AM
JRYELLOWCORVETTE's Avatar
JRYELLOWCORVETTE
Default Trickle charge issues
Has anyone had problems with the Corvette charger that plugs into the 12v outlet? They charge $100 for this and after being gone for 6 months my battery was stone cold dead! It took 24 hrs to charge the battery up .
Old Nov 4, 2016 | 12:05 PM
Zymurgy's Avatar
Zymurgy
Moderator
Did you have it plugged into the socket in the rear compartment? It is the only one that is active when the car is off.
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Is the outlet "hot" when the ignition is off?
Old Nov 4, 2016 | 03:38 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
YES, the one in the trunk/hatch area is hot! with ignition off!
Old Nov 4, 2016 | 03:39 PM
speedlink's Avatar
speedlink
That's the answer.
Old Nov 5, 2016 | 07:51 AM
JRYELLOWCORVETTE
No I plugged in into the one on the console ��
Old Nov 5, 2016 | 08:04 AM
pastohio's Avatar
pastohio
Last winter I did the same thing, plugged mine in for the winter, after 5 months...tried to start car and it was dead.....had to replace the battery and get a new charger....some people say good things on this site about the chargers BUT I find them to be crap....IF battery has been taken down and can't start the car, then you need to replace the battery as well...my $.02
Old Nov 5, 2016 | 09:12 AM
C7 Vert's Avatar
C7 Vert
He charger IS made to plug into the outlet in the trunk area. Won't work by plugging into the console.
Old Nov 5, 2016 | 09:14 AM
REZ1's Avatar
REZ1
There Ya go..problem solved..!
When all else fails....read the Owners Manual
Old Nov 5, 2016 | 10:55 AM
Sounds like you plugged it into the wrong power port.
Old Nov 6, 2016 | 10:33 AM
JRYELLOWCORVETTE
Sure did... I did not even. know there was a trunk plug. When I bought the car the salesman pointed to the consol outlet and he was their
Corvette Specialist. LOL
Problem solved !
Old Nov 6, 2016 | 12:18 PM
Squeaky Wheel's Avatar
Squeaky Wheel
Part of the problem may be that on the C6 (not sure about the C5) you could use the outlet in the front console for the recharger plug, and since many of us were former C6 owners, we just assumed it would be the same on the C7. I would have made the same mistake without reading the C7 manual. Actually, I think I learned it here first.
To Trickle charge issues
