Thoughts on Borla X-pipe
Old Jan 4, 2017 | 03:17 PM
SCorvette08's Avatar
SCorvette08
Default Thoughts on Borla X-pipe
thoughts on Borla X pipe Add horsepower, reduce horsepower ,
Great sound, not much difference , worth the money , ????
thinking about doing one
Old Jan 4, 2017 | 07:11 PM
9157's Avatar
9157
Naples FL
great impovement for the money; does all of the above; strongly recommend. I also added a K&N drop in filter for the stock air box.
Old Jan 4, 2017 | 07:56 PM
cwing85b's Avatar
cwing85b
Old Jan 5, 2017 | 04:38 AM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Like we discussed.
Worth it!
-Josh
Old Jan 5, 2017 | 07:58 AM
John58's Avatar
John58
Veteran: Marine Corps
It's a "Must Have"... I gain both (Horsepower and Great Enhance Sound)
Old Jan 5, 2017 | 08:08 AM
fun ticket's Avatar
fun ticket
Not to hijack the thread because I am considering the same purchase and am interested in the real benefits. I only plan to do the x pipe as I just dont trust anyone on removing the rear fascia to install a cat back as well which leads to my question......x pipe installs.....anyone know any installers in the tampa, st pete, clearwater, sarasota area that have experience with this installation on a c7?
Old Jan 5, 2017 | 08:31 AM
rrsperry's Avatar
rrsperry
Sorry it's a muffler pipe. You take off about 30 bolts, remove a brace, loosen 4 clamps, and replace it. It's not rocket surgery.
Old Jan 5, 2017 | 08:56 AM
PegasusCapital's Avatar
PegasusCapital
CF Senior Member
I agree, it's a must have mod. You get all the benefits listed above and the cost is relatively cheap. I just love the way my Callaway sounds and I can still control it with NPP.
Old Jan 5, 2017 | 10:04 AM
Speedforhire's Avatar
Speedforhire
So easy a CAVEMAN can do it.
The tedious part is removing the tunnel plate. A RPITA! I think GM could have used half of the bolts they actually installed.
FWIW! I did a comparo about the decibel levels and it was only a 5db increase at idle (10" behind the vehicle) and no measurable interior increase (and no drone). WOT is music to the ears.
Old Jan 5, 2017 | 10:06 AM
ssidekickbp's Avatar
ssidekickbp
Can you post a link to that K&N drop in filter? Thanks!
Old Jan 5, 2017 | 10:35 AM
fun ticket's Avatar
fun ticket
Agreed, but you know as well as I do there are some real clowns out there that claim to be mechanics, etc, sloppy work, don't tighten bolts, etc, etc. I would do it myself but I do not have access to a lift.
Old Jan 5, 2017 | 11:08 AM
joemessman's Avatar
joemessman
Is it just the Xpipe itself you want? Or the whole package with Atak? If if is just the Xpipe I don't think there is much gain in horsepower. Maybe 5 HP or something like that. But the sound is fantastic. It gets you 90% there for the sound on just the cost of the Xpipe at about $450, as opposed the the whole Atak package for around $2,000. I believe the full package will gain you about 40 HP.
Old Jan 5, 2017 | 12:35 PM
halt00's Avatar
halt00
Worth it for the cost, if you have NPP, don't bother with aftermarket exhaust, practically the same (as you'll read on other threads)
Old Jan 5, 2017 | 12:39 PM
kenownr's Avatar
kenownr
You guys that have them; purchased from forum vendors?? Recommendation --
thanks - tom
Old Jan 5, 2017 | 03:04 PM
MerakiAutoworks
Supporting Vendor
thanks - tom
You can get it from us!
--Josh
Old Jan 5, 2017 | 03:21 PM
lancekl's Avatar
lancekl
You don't need a lift. Jack up one side of the car and put it on jack stands.
You can do the whole job from one side. Easy install, worth the money
Old Jan 5, 2017 | 03:27 PM
joemessman's Avatar
joemessman
thanks - tom
Here is the part you want to buy, and they run four to five hundred dollars:
Borla 60547 X-Pipe
To Thoughts on Borla X-pipe
Old Jan 5, 2017 | 03:31 PM
Kracka's Avatar
Kracka
Agreed. 1 jack, 2 jackstands, and some basic hand tools is all you need to get the job done.
Old Jan 5, 2017 | 03:33 PM
joemessman's Avatar
joemessman
I can hardly screw in a light bulb, but I did this myself. One thing though is one pipe was a little out of round and I had to pound it little to perfect it so it would fit.
Other than that, if I can do it, anyone can. So have confidence.
Old Jan 5, 2017 | 03:35 PM
NakedDave's Avatar
NakedDave
When doing it on jackstands and "pulling" the X pipe loose from the muffler over axle pipes, don't drop it on yourself, it hurts!
