Simple, short shift at anytime before 14 mph and save even more wear and tear while you're warming up, and you'll never see a 1-4 shift.
but I don't even want to have to think about this at all while driving. Plug it in, don't ever have to pay attention if I'm short shifting or not, revving high enough or not. Just drive and don't worry about it.
I have said, it is hardly needed with the C7, it rarely comes on, but when it does, it bugs me so I would rather not ever have to deal with it.
But the light is only on for a second like when cars tell you when to shift. And it should only come on when I am basically crawling, like pulling away from a light or in a jam correct?
You may not know this since its not your car, but will the original connection be hanging freely, or should I ask if they have the original connector?
If it's hanging loose it will hit the exhaust.
if you can jack u0 the car o r put it n a lift just remove and repug. Very easy.
Frankly with todaysdistraceddriving I would not drive without it. First time it happened to my I was in bumper to bumper travic. Car would not shift to 2nd and having installed CAGE eliminator in my C6 thought it was me. Car slowed to craw. Had the person behind received a beep on their phone could have been in my rear
For $20 bucks if you own a jack easy install and no issues. This is a silly thread. Justifying not adding one is a wast of electrons IMO !!
Thanks for the info.
The thread really wasn't about "should or shouldn't". It was about learning how it works and it effects on the car. Its just morphed a little into both.
I find the CAGS defeat worthwhile, as I don't need to rev my engine from 800RPM to redline through every gear....
What is it about shifting from 1 to 2 before 14 mph or after 18 mph that you don't understand? That little 4 mph window between 14 and 18 sure is important to some people.
Carry on . . . The little things that bother people never cease to amaze me. What does revving "from 800 to redline through every gear" have to do with anything being discussed here?
And I'm equally baffled why anyone would EVER worry about it. I don't care if it costs 99¢.
I daily drive my Corvette, so I may encounter the despicable "1-4" more than others. For example, I'll encounter it often when making a left turn at a 4-way stop. In situations like that, I'm typically not revving the engine up at all, and the "1-4" forced missed shift in the middle of the intersection is annoying as hell.
If I only tracked my car, or only drove it occasionally for thrill rides, I'm sure I wouldn't encounter it nearly so often.
And you're absolutely correct - I *could* adjust my driving habits to avoid shifting in that narrow band. My point was, for $20 or less, why not eliminate the goofy "1-4" gadget all together so you don't HAVE to even think about it?
And someone who actually says, "I would not drive without it," is a lot more silly than this thread.
Originally Posted by Kent1999
I daily drive my Corvette, so I may encounter the despicable "1-4" more than others. For example, I'll encounter it when making a left turn at a 4-way stop. In situations like that, I'm typically not revving the engine up at all (no need to 'drift' through every intersection in residential neighborhoods), and the "1-4" forced missed shift in the middle of the intersection is annoying as hell.
I daily drive mine in the 2nd worst traffic in the nation. I've never encountered it, and yes, I sometimes do shift to 2nd immediately at 10 mph or so . . . no need for CAGs, and I don't have to think about it.
Not trying to start another argument, but if you can hide those in your grille they do work. They don't scare deer, but it freezes them because they hear a noise. Its like when they hear a leaf crackle in the woods, the sit up straight and listen. In the car instance, they wouldn't dart across the road, they would wait and listen to see what the whistle is. They might go after, but hopefully you are passed them by then.
That said, I don't have them.
Nope sorry, the science says they are ineffective.
I am not going to debate this. I have read several articles that say different. Plus, I have seen it in a car that had them. Now, it could have just been the noise of the car that caused them stand up and listen, but that is big coincidence considering I have driven by plenty of deer that didn't sit up and listen when I came by. But let's not get off topic here.
For someone who finds this thread silly, you sure are posting a lot. I am finding it informative. It is unfortunate that you are finding it annoying.
i am not going to debate this. I have read several articles that say different. Plus, i have seen it in a car that had them. Now, it could have just been the noise of the car that caused them stand up and listen, but that is big coincidence considering i have driven by plenty of deer that didn't sit up and listen when i came by. But let's not get off topic here.
You guys sure are "passionate" about a $20 mod on a $50,000 car....that some people (including me) want.........and then spend thousands of dollars on 2LT or 3LT toys....
I paid $12 for my CAGS defeat on Ebay.....
i paid $0.00 to burn the fuse. and it worked perfect in my C6
