Removed top security
Old Jun 8, 2017 | 04:07 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by ~Stingray
What trim level does that come with?
I think they're on everything except the level 1 cars (1LT, 1LZ) for 2017. Not sure, especially about previous years.
Old Jun 9, 2017 | 11:22 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Anyone else? Did the motion sensors come on the previous model years?
Old Jun 13, 2017 | 07:18 AM
~Stingray's Avatar
~Stingray
no body knows?
Old Jun 13, 2017 | 08:17 AM
Thanks for all the good info in this thread.
Old Jun 13, 2017 | 11:47 AM
dbdave's Avatar
dbdave
Yes.
Old Jun 13, 2017 | 03:09 PM
vettetwo's Avatar
vettetwo
I have a 2014 3LT A6. I locked the car with the windows open. I reached in and opened the glove box. No alarms, so apparently the motion sensors are not activated with the windows down and the glove box opened.
Old Jun 13, 2017 | 04:59 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Did you wait for the solid red lamp on the dash to start blinking?
I have a 2014 3LT A6. I locked the car with the RKE and the windows are open. I reached in and opened the glove box. It alarms. Actually, I just reached in and it alarmed.
Elmer
Old Jun 13, 2017 | 05:35 PM
vettetwo's Avatar
vettetwo
Elmer
Thank you Elmer. I did not wait for the light the first time.
Mine also alarmed and the glove box was locked with the windows down and top on.
Old Jun 13, 2017 | 06:23 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
Even with the M7 in reverse, you can open the screen hideaway after a given amount of time. Not sure how long it is, bit it will open after sitting a while.
Old Jun 13, 2017 | 07:32 PM
JNess's Avatar
JNess
Next to the hatch release is a button that allows you to disable the motion sensor.
That should both tell you if you have one, and give you the ability to check to see if you've inadvertently disabled it.
It looks like it is for wifi. If you toggle it on and off, you'll get a beep and the screen will tell you motion sensor disabled.
Old Jun 23, 2017 | 11:25 AM
Gary2016's Avatar
Gary2016
[QUOTE=eboggs_jkvl;1594897512]Mostly true but you can put a plug into the driver's side hole at the top of the windshield and all the alarms will set including intrusion. Sadly, the convertible can't be armed in this manner and while I can turn on the door alarm, intrusion stays off with the top down.
I tried to do this with no luck. I even tried holding a flat head screw driver against the pin then locked the car. Is there an amount of time it takes for the motion sensors to activate? Do you have a pic of the cap you used? Thank you
Old Jun 23, 2017 | 11:43 AM
eboggs_jkvl
Moderator emeritus
[QUOTE=Gary2016;1595004550]
Look here: https://www.corvetteforum.com/forums...post1586628970
When everything is closed (or thinks it's closed) the alarm takes about 30 seconds to set. Look at the red light on the dash. When it starts to blink slow, the alarm is active.
Elmer
