MDI....... which one?
Old Feb 24, 2018 | 01:35 AM
  #41
Dano523's Avatar
Dano523
Originally Posted by Dale002
Dano523, I just go in but will try this in the morning. I'll let you know how it worked out. Thanks.
No worries, and if you run into a problem still, drop me a PM.
Hence I can write the novel on how to go into Device manger in both win 7 and in the VM Xp shell to make sure that the GM nano is showing up in the device manager to start with, and on the correct port setting if you can not connector the GDS2 to the nano, but lets cross that bridge if it becomes a problem instead. Hence the Usb gm nano device should be on com 3, and if it not, then click on it in device manager, go to advance settings, and change it to com 3.
Also, don't forget to open VX mdi driver program in win 7 (not the vm shell since it blocked from the internet), update the firmware, and update the licenses too.
Old Feb 24, 2018 | 01:17 PM
  #42
Dale002's Avatar
Dale002
Have no problem getting to the d drive and opening it up,It's that it only shows 3 files. hidden files are on
GDS2 VM
Tech2Win
VWware-player
Old Feb 24, 2018 | 02:04 PM
  #43
Dale002's Avatar
Dale002
I can down load the VMware player
Old Feb 24, 2018 | 03:49 PM
  #44
Dano523's Avatar
Dano523
PM me with a phone number to call you.
Hell, if you want to run GDS2 from a Ipad, I can help you set that up as well.
https://itunes.apple.com/us/app/vm-p...207969344?mt=8
Old Mar 2, 2018 | 10:15 AM
  #45
Dale002's Avatar
Dale002
I'm connected! Thanks to Dano523 for all the help.
Old Mar 12, 2018 | 08:57 AM
  #46
Scottcolem's Avatar
Scottcolem
quick question, I just ordered a GM MDI because I added competition seats 3LZ to my 1 LZ. verified all the wiring is in place and installed the new HVAC panel. im guessing I need to program the BCM and possibly the HSCM so it will recognize the equipment is installed in the car? are these VIN specific or something much simpler? thanks for the help
Old Mar 12, 2018 | 10:52 AM
  #47
Jeff V.'s Avatar
Jeff V.
You need a subscription to AC Delco TDS (acdelcotds.com) in order to program modules. $40 for 2 years access to programming for one VIN.
Old Mar 24, 2018 | 06:13 PM
  #48
Dano523's Avatar
Dano523
Quick update since I just went through this will Paul.
The $40 subscription for GM is for the C7 as well, but will just get you SPS from the web site only. So you going to use the VM GDS2 for the rest of your needs, short of needing firmware files or needing to do TDS programing like programming in a fob or pairing the ECM to BCM again (which is the imoblizer relearn setting from the list of modules in SPS,and once selected, will load a special menu list to use for such).
Note, the first Vin # you use to pull down a firmware file with TDS, it will lock your $40 subscription to this vehicle.
On the AC/Delco TDS, Once you pay for the subscrition, the first time setting up TDS is will a little daunting and you have to use internet explorer. The first thing once you click the SP button will be Java set up, so you will need to first load that to your machine (it going to take a few steps to get it finaly loaded with the correct update). Next, you going to get a screen that will tell you that you have to make exceptions your allowed list in internet exporer (gm site and Java site), but easy enough as well since it will walk you through the process. Next your going to download the TISWeb ICVS5b proxy software and install it. about the last pop up screen your going to get is small square screen that will have a MDI and Tech II driver. Do not install these, but just click skips instead.
Note, every time you use SPS after you have it set up on the machine and start SPS, your going to get the driver pop up screen, so remember to press skip each time!!!!!
So before you use/set up TDS after you have paid for your subscription, back in the VX MDI driver folder from the windows start icon in programs, click on VX driver mdi, and it will load the VX manager (have the GM nano plugged in to the computer). Once the VX manager loads, click on diagnostic tab on the top of the screen and install both the pass through and T2w drivers from the your apps menu on the left.
Now when you go to use TDS SPS, when you come to the device screen, your going to select the VXDiag device, which you loaded the needed drives from the VX manager to your machine.
Again, when you go to use TDS SPS each time, skip the part to installing the Tech ii and MDI driver. If you do not get VXdiag device in the TDS device select screen to select the VX Nano, it's due to you not installing the needed pass through and t2w drivers in the VX manager before hand, or you installed the SPS MDI or tech II drivers.
Old Apr 15, 2018 | 07:52 PM
  #49
badhabit_wb's Avatar
badhabit_wb
Does all of this work the same way with the Mongoose Pro 2?
Old Apr 15, 2018 | 08:04 PM
  #50
dmaxx3500's Avatar
dmaxx3500
go find a ''MDI-2'',just changed from a mdi-1 and its 2x faster
Old Apr 15, 2018 | 08:16 PM
  #51
badhabit_wb
I already have the Mongoose Pro
Old Apr 15, 2018 | 08:26 PM
  #52
sonny615's Avatar
sonny615
Would like to know more on this if possible.
Old Apr 15, 2018 | 08:50 PM
  #53
Jeff V.'s Avatar
Jeff V.
Yes, it does.
Old Apr 15, 2018 | 08:51 PM
  #54
badhabit_wb
Thank you
Old Apr 16, 2018 | 08:54 AM
  #55
user051728's Avatar
user051728
Just get a Bosch Master Tech. It's $100 more (typically) and works multi OEM. Bosch makes the MDI and MDI2.
https://www.boschdiagnostics.com/pro...m-hardware-kit
https://www.boschdiagnostics.com/pro...ral-motors-mdi
Old Mar 28, 2019 | 11:46 PM
  #56
carfashion2's Avatar
carfashion2
1st Gear
I seem to be having com problems with C6 2006 corvette MDI clone dont connect to vehicle also autel can read and scan it
Old Mar 30, 2019 | 02:03 AM
  #57
Dano523's Avatar
Dano523
Go into device manager with the mdi plugged in to the laptop, click on ports arrow (com &lpt), the double click on usb (what every port is on) to go to port settings, click on advance, and change the port to 4 or 5. Now back in settings, 9600 bit, 8 bit, polarity none, stop bits 1, flow control none.
Now reopen allscanner and see if the device is listing. If not, then in all scanner (VX driver MDI), make sure to update the firmware by clicking on that icon, then click on the license icon next to update the liscense.
If still having problem, with all scanner still open and the MDI clone still plugged in, go back and reinstall GM MDI driver, then install the Tech2 win software (auto install), but with XV driver mdi/all scanner open and the MDI still plugged into the machine.
Hence in windows 10, you have to have the mdi clone first firmware updated and license updated, the MDI left plugged in and all scanner open when you install the other two programs via auto install in the MDI folder.
GM MDI first installs the needed MDI drivers and has to see the MDI, then tech2win will go in and modify the GM Mdi file, VX driver MDI files that has to be open as the same time with the MDI clone plugged in.
So XV driver mdi from the disc first, update firmware and license the of the clone MDI, leave VX driver mdi/all scanner open and clone still plugged in, the use the auto install to install the new two programs in that order from the MDI folder.
If you are still lost, then send me a PM (click on my name) with your name and phone number, and I can call you to talk you through getting the MDI clone working over the phone.
