Nail in run flat
This is why carrying a small air compressor is such a good idea even with runflat tires. It's even more so if you don't have runflats. This non runflat Michelin all season tire picked up two screws simultaneously and with one refill from my air compressor was able to drive it 50 miles home with the screws in the tire. I pumped it up to 42 psi and it had only dropped to 36 psi by the time I got home.
Discount Tire was about 3 miles from my house. They actually happened to have ONE correct tire on the shelf (that's another story in itself).
The manager warned me they had previously been unable to air up a new tire on another GS like mine. After about 90 minutes they gave up. Patched and plugged remounted old tire and I drove to Suburban Chev about 20 miles away. Matt in the tire department had the new tire mounted and balanced in about 20 minutes and I was on my way.
Thanks Matt and Suburban! You will get all my future Corvette tire business!
I do the same. Have a small compressor that fits in the rear compartment. It is typically in the wife's SUV that also has run flats as we mostly use it for long trips. But I put it in the Vette for a ~2 1/2 hour trip to the Charlotte zMAX Dragway along back roads were there is not a tire shop I would trust to fix them.Just called Discount Tire to see what it would cost for tire insurance for the new SUV, for what I bought for the Grand Sport. The tires on the 2018 BMW X5 all wheel drive are not quite as expensive but almost as wide so will be nail magnets! It has Continentals, 275/40/20 fronts and 315/35/20 on the rear! Almost as wide as the Grand Sport tires! $180 for tire insurance, which I will get.
Well worth it IMO!
Too much non repairable area with those wide tires! Bought yesterday for wife's SUV.
With these wide tires, need a good tire store!
That was the original figure that GM and GY came up with as a reasonable compromise between what the tire was capable of and how far GM dealers were apart. They determined that the tire could be safely fixed when driven at ZP for 50 miles at less than 50 mph and the available dealerships were at the most ~100 miles apart (nevermind that at the time, most dealerships were not equipped to deal with the tires) . This also did not really figure in GY dealers, who were even later in adopting machines that could deal with RFs.
Now, with the C7, Michelin has decided that the tire can have one fix (patch/plug from the inside) if not driven at ZP. The reasoning with this The tires are now, and always have been able to drive much further than the 50 miles at ZP to get you where you need to go safely, but no real way to determine how much structural damage has been done when driving at ZP.
The lawyers say there is no way to know, but the tires are capable of driving much further than 50 miles to safety, regardless.
The numbers go up and down. IIRC, we had two different years of C6, one manual said 25 miles flat was ok, the other said "as little as possible".
Our C5 was 50 miles.
Our 2017 C7 Owner Manual says 50 miles at 50 mph should be ok, but personally I'd be surprised if the tire was still repairable at that point.
We had one fellow who posted driving several hundred miles on a flat runflat which he knew was ruined (huge cut), because it was a weekend with no replacement available. He stopped only because he got home and the tire was still intact.
Reason I keep a small pump in the rear compartment when on long trips. You can watch the pressure drop so if you can’t find a location with a “real pump” to get it to ~40 psi, which should last some time with just a nail, can use the small pump. If the air leaks out fast, it’s less likely to be repairable anyway.
Can anyone clear this up for me? It's just a small screw. I don't track the car, it's a weekend driver. 2017 base Stingray.
