Quickjack 5000 question
Old Mar 31, 2018 | 05:19 PM
walleyejack's Avatar
walleyejack
Default Quickjack 5000 question
i have the quickjack 5000, raised my car a cpl times to do exhaust work.
but i don t see the rubber blocks lining up with the pucks at all.
is front or rear,unless i m dumb, line the front ones up properly, but the rear trays do not allow the blocks to be slid ahead far enough to catch the pucks. i have the blocks moved as far ahead as possible on the back and far back as possible on the front. i put the blocks in and lift on the back approximately 4" to the rear of the puck. has anyone else had this happen ? i know the QJ 3500 is 8" shorter, so maybe that is the difference.
Tia al
Old Mar 31, 2018 | 05:44 PM
laserdude2215's Avatar
laserdude2215
u hav the jacks bacwerds.
Old Mar 31, 2018 | 06:05 PM
walleyejack
I was told when it lifts, it goes forward. Not lifting to the back
Old Mar 31, 2018 | 06:38 PM
banph's Avatar
banph
2023 Corvette of the Year Winner - Unmodified
2022 C2 of the Year Winner -- Unmodified
No, when it lifts it goes backwards.
Here are some pictures of it in the up position. I have the 5000 model.
After viewing the other post, I guess it does not matter which way it goes up, I have always just done it from front to rear.
My blocks line up perfectly with my Jacking pucks on the frame, both for my 08 Z06 and the 17 Grand Sport
Old Mar 31, 2018 | 06:46 PM
walleyejack
Ok thank you. Will try that, most videos i watched have them going forward. I have my lines going over top the jack just under the car body. I believe there is no chance of pinching them as blocks leave enough space.
Thanks for you input and pics.
So far i love it.
Old Mar 31, 2018 | 08:10 PM
tbran6's Avatar
tbran6
Default your stoppers
look at those CCB's. nice
Old Mar 31, 2018 | 09:55 PM
Busted Knuckle's Avatar
Busted Knuckle
Default What it should look like !!
Here is the BL-5000 lifting a Z !!
Old Mar 31, 2018 | 10:08 PM
TEXHAWK0's Avatar
TEXHAWK0
Just watch the You Tube video
Old Mar 31, 2018 | 10:09 PM
walleyejack
when it goes up, it moves forward or backward ?
Old Mar 31, 2018 | 10:11 PM
Baron37075's Avatar
Baron37075
Amazing that the Corvette CCBs are larger than the 14” wheels on my first car (‘81 Olds Cutlass). Wow!
Old Mar 31, 2018 | 10:12 PM
walleyejack
https://www.youtube.com/watch?v=bHlOUA6qyR8
watched it many times. and that is how mine is set up. but, i have the longer block trays and not hitting the puck points. that may be a 3500 model there and is 8" shorter.
Old Mar 31, 2018 | 10:17 PM
iclick's Avatar
iclick
...i don t see the rubber blocks lining up with the pucks at all.
Could you post a photo showing this? Mine line up fine.
Make sure the lines are positioned as you see them in the still photos above. Don't let them get routed on top the jack so that they move with it and stretch when elevated, as the blocks may compress and potentially pinch them against the top bar of the frame. On mine the yellow instruction label end of the jack is at the front of the car, as mentioned in the manual (p. 12), but the video shows it both ways in different places. This is confusing.
The manual says the opposite, but I'm not sure it would matter if your compressor is at the front as in your case. Mine is in the rear and I have it raising to the front.
Old Mar 31, 2018 | 10:47 PM
walleyejack
i really can t see mattering which way, unless the trays are different positions on each end. i will crawl around tomorrow and take some pics.
will send a cpl from my cell i took today
Old Mar 31, 2018 | 10:51 PM
walleyejack
Old Mar 31, 2018 | 11:46 PM
taz2016's Avatar
taz2016
Doesn't matter which direction it lifts from. Use whatever works best but make sure they are parallel.
Old Mar 31, 2018 | 11:54 PM
Old Yellow's Avatar
Old Yellow
Direction of lift doesn't matter.
I use them sideways for winter storage. Gets her right up against the wall nice, and tight.
Ed
Old Apr 1, 2018 | 01:38 AM
C83LZ's Avatar
C83LZ
I honestly thought this was a completely different topic......wow.
To Quickjack 5000 question
Old Apr 1, 2018 | 08:24 AM
Apocolips's Avatar
Apocolips
Ed
Wow, I never would have thought of that. Great idea!!!
Old Apr 1, 2018 | 10:35 AM
walleyejack
Some pics of how the blocks line up with the pucks. 2 with the labels to the rear and 2 labels to the front. There is no chance the back blocks
Old Apr 1, 2018 | 10:36 AM
L1FRDOG's Avatar
L1FRDOG
I lift my 2017 GS routinely and the lift moves forward when lifting and I have no fit meant issues with the pucks.
