2014 A6 2-3 shift problem
When in D & full throttle , A6 shifts from 2-3 & I let off throttle .. stays in 2nd till I put in nuetral then back to D. note this is at full operating temp & in D mode.
took to local dealer & told this is a normal characteristic of the transmission, a cold 2-3 flare caused by air bubble ....... my 2007 did not have this problem.
The dealer did not have a mechanic check out , or diagnose problem @ told me to take to the dealer I purchased from..............so I will be setting up apt at Malmulkin......has anyone had this A6 problem with a C7 A6 ?
My thoughts a TCM calibration should be done ? anyone s info will be appreciated, Thanks the Dog
But, did you mean when it shifts from 2nd to 3rd at Full Throttle, it stays in "3rd" when you let off the throttle ?
How long does it stay in that gear if you don't do anything like putting it in Neutral.
Do you know about the Performance mode it goes into at Full Throttle ?
With Full Throttle it will stay in a gear after letting off the throttle.
It does this because it thinks you're racing and will need that gear to keep accelerating.
Stay off the Throttle long enough, and it will automatically drop out of Performance mode and back to normal D Auto mode function.
Another way to make it go back to D normal Auto mode function is Manually change gears, up shift, with the Paddles while it's still in D.
Here is a thread asking the same thing.. https://www.corvetteforum.com/forums...hift-mode.html
Hope this helps
