Quote:
Which fuse?Originally Posted by jabeasley1
i literally had this code last month. Under my hood in the fuse box was the BLOWN FUSE. Hope this helps
Cleared the code and drove the car. Check Engine light did not come on, at least for now. Will drive it again tomorrow to see what happens.
IAIA
close
- Member SinceDec 2006
- LocationOrange County California
Liked:104 Times in 82 Posts
Happened to my C6 Z06 a LOT. Sometimes said "check gas cap," and sometimes it was just the engine light. After half a tank, or another tank of gas, it disappeared. Lot of threads about this on the C6.
MMD
close
- Member SinceMar 2018
Liked:1,650 Times in 1,053 Posts
Quote:
Code P0442 confirmed.
All they did was under warranty.
Hopefully this is the final chapter. Best wishes.Originally Posted by Flo
Car was yesterday to the dealership.Code P0442 confirmed.
close
- Member SinceMar 2001
- LocationIn a parallel universe. Currently own 2014 Stingray Coupe.
- Veteran Field #1C7 of the Year - Modified Finalist 2021
- Veteran Field #2MO Events Coordinator
- Veteran Field #3St. Jude Co-Organizer
- Veteran Field #4St. Jude Donor '03 thru '25
- Veteran Field #5NCM Sinkhole Donor
- Veteran Field #6CI 5, 8 & 11 Veteran
Liked:24,733 Times in 17,577 Posts
Quote:
You could take it to your local parts store right now and most stores will have an OBD II (On Board Diagnostics) hand held reader on hand. The parts store offer this service free. Just call in advance to be sure. Shouldn't take more than a minute or 2 to do.
It will at least give you an idea of what to do with the car - self repair or time to go to a dealer.
