ECO Mode???
Old Jan 16, 2019 | 03:14 PM
Dave502's Avatar
Dave502
Default ECO Mode???
Have a friend with a 2016 and he says he can feel it go into ECO mode without having switched to ECO. .He feels it in Touring,Wet etc......Does it need to be in ECO MODE to work and change to four cylinders at speed....My 2015 is heavily modified and ECO was deleted in tune and I can't help him???
Old Jan 16, 2019 | 03:22 PM
dvilin's Avatar
dvilin
With a M7 you must put it into ECO mode not so with the A8.
Old Jan 16, 2019 | 03:31 PM
Foosh's Avatar
Foosh
The only OEM way to avoid V4 mode in the A8 is to put the shifter into the manual shift position and use the paddles. Tuning it out is an option if you don't care about having your powertrain warranty blocked.
Old Jan 16, 2019 | 03:40 PM
Skid Row Joe's Avatar
Skid Row Joe
If it's the M7, (manual transmission) then, yes.
If it's the A8 transmission, then no, it will always engage V4 mode.
Old Jan 16, 2019 | 03:46 PM
Dave502's Avatar
Dave502
Thanks everyone,I'll pass this on to him.....So the ECO MODE position on A8 is worthless...That's what he has
Old Jan 16, 2019 | 04:02 PM
Woodson's Avatar
Woodson
Also worthless in the M7 imo.
Old Jan 16, 2019 | 04:17 PM
Rebel Yell's Avatar
Rebel Yell
The A8 transmissions are designed to go into V4 mode any time the parameters are met, and that is a lot with these trannys. The Eco mode with an automatic just keeps the car in V4 mode longer while cruising at highway speeds, and the engine with still move between V4 and V8. The V4 mode can be defeated in two ways that will not void the warranty. The first way if to put the trans in sport mode, and shift with the paddles. The second way is with a Range Technology AFM (V4) disabler. www.rangetechnology.com. Many here use the Range unit.
Old Jan 16, 2019 | 04:19 PM
LuisZ51's Avatar
LuisZ51
How so? On long highway trips it saves gas for me.
Old Jan 16, 2019 | 04:28 PM
Foosh's Avatar
Foosh
Yes, it's great for that. Another thing I like about the M7 is that I never have to see V4 unless want to save some fuel while cruising at 70 in 7th on a road trip by switching to ECO. On the A8, it can go into V4 in any mode, unless you switch to manual shifting.
Old Jan 16, 2019 | 04:48 PM
Woodson's Avatar
Woodson
Personally I'd rather avoid any potential V4 issues in order to save a few pennies. I haven't seen any quantifiable proof that it even saves any gas, especially at little over idle RPM's in 7th.
Old Jan 16, 2019 | 05:39 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Can't speak (yet) for my Grand Sport but I was reluctant to use it in my '14 Z51 M7 until one day I did. It did make a small difference in mileage for me - maybe 1 to 1.5 MPG on longer highway trips increase.
Quite literally, your mileage may vary
Old Jan 16, 2019 | 06:09 PM
Patman's Avatar
Patman
I have found it gives me about a 5% boost in MPG so that's pretty significant.
I'm not sure what issues you'd be worried about with the M7 and V4 mode though. I know a lot of A8 guys try to avoid V4 at all costs to avoid any torque converter issues, but I've never heard of anyone with an M7 having a problem related to AFM. If you're just going to be cruising along for long periods of time on the highway you might as well use it, it's free money in your pocket.
Old Jan 16, 2019 | 10:51 PM
owc6's Avatar
owc6
Yes, and no.
Putting an auto into ECO will extend the parameters that the car will go into, and remain in V4. It may be only slightly, it may or may not be important to you, but that's what it does.
Old Jan 17, 2019 | 11:36 AM
Maxpowers's Avatar
Maxpowers
I can't stand the way I can feel it when it switches in and out of V4 mode when cruising down a long stretch of highway. It is very slight (my wife can't tell), but I can and it drives me nuts.
Old Jan 17, 2019 | 11:43 AM
Parcival's Avatar
Parcival
meh evidence, I bet it does use less just because the science of fewer cylinders means less gas consumption...
issue is do we care or notice. Long highway trips for sure which is when I use Eco. Not so much everywhere else, So i use Tour or sport most days.
Old Jan 17, 2019 | 11:51 AM
Woodson's Avatar
Woodson
Yeah, I turn off the auto shut-off on my wife's Merc when I'm driving that. The annoyance isn't worth the pennies saved imo.
Old Jan 17, 2019 | 12:06 PM
Mayor111's Avatar
Mayor111
Im not disagreeing with you Patman - Im also no mechanic so this is just purely guessing here - but would you think that the cost to repair the mechanics and technology behind changing from V8 to V4 is "unnecessary" given the few bucks you might save annually? In other words you said its a 5% savings. So lets say you get 30 MPG in V8 mode...if you increase that by 5% you then would get 31.5 MPG... If you have (just for ease of math) 15 gallons in your tank at all times - then your getting an extra 22.5 miles more each tank - that's about $3 worth of gas per tank-fill. So does $3 of gas (22.5 miles) really equal the major cost of issues that "could" arise in the engine by switching from V8 to V4? Again - I dont know - Im asking.
To ECO Mode???
Old Jan 17, 2019 | 12:25 PM
lakemg's Avatar
lakemg
I frequent this site a lot and I have yet to see any engine failures or needed repairs due to the engine switching between V8 and V4. Now if we roll back to 2009 during my Pontiac G8 GT days, yes we saw quite a few failed lifters because of the DOD design, but that was a Gen IV engine and I've not seen that issue with the LT1 engine, at least not yet unless I missed it.
On the other hand, I do see issues here with the A8 transmission, due to the V4/V8 technology...
Old Jan 17, 2019 | 12:27 PM
Patman's Avatar
Patman
You raise a valid point, but so far it does seem like the AFM hardware itself is pretty solid on these cars, as I can't recall a single person on here reporting any issues in that regard just yet. I guess we'll know for sure once more owners start getting much higher mileage on their LT1s (and they'd have to be owners that use the AFM frequently, like myself)
Old Jan 17, 2019 | 12:34 PM
yokennyr's Avatar
yokennyr
I have a ‘14 Stingray bought with 10,000 miles back in November. I don’t notice anything at all when it shifts between the v8 and v4.
Once I found the dash setting where you could see it, I was watching it for a few weeks and never noticed. I’ve since stopped watching.
I have only been on short drives since delivery...1 or 2 hours...but I had a 8 hour drive home when I picked up the car. I had it in ECO mode and it seemed to just sip gas. I will certainly use it for longer trips.
