Automatic transmission problem
Old Feb 24, 2019 | 07:05 PM
NSC's Avatar
NSC
2nd Gear
Default Automatic transmission problem
Hello, I have a 2014 C7 with automatic transmission. It has less than 11,000 miles. On rare occasions it takes a long time to shift from 1st to 2nd. Between 40-50mph. Has anyone else had this problem. Thanks
Old Feb 24, 2019 | 08:16 PM
LarryFL's Avatar
LarryFL
Search forum for "transmission problem". You might something.
Old Feb 24, 2019 | 09:47 PM
Haven't heard too much about the A6 having problems but anything is possible. Will follow this to see what others have to say.
Old Feb 24, 2019 | 10:18 PM
Dcasole's Avatar
Dcasole
Shift flair , common problem with the A6 , not just in the vette but all cars and trucks that have the trans . have to clear the trans adapts , do a garage relearn , then do the street relearn process ...will feel like a new trans
Dave
Old Feb 24, 2019 | 10:47 PM
Jmhornz71's Avatar
Jmhornz71
If this occurs when the car is cold the transmissions will hold a gear longer than normal
Old Feb 24, 2019 | 10:54 PM
owc6's Avatar
owc6
It will also take longer to shift at low RPMs.
Shift at WOT, and it will shift like bam! Literally.
Old Feb 24, 2019 | 11:46 PM
4thC4at60's Avatar
4thC4at60
Being a 2014 I'd start with a transmission service: new fluids, new filter..... it's six years old
Old Feb 25, 2019 | 12:00 AM
owc6's Avatar
owc6
Good point.
Old Feb 25, 2019 | 07:54 AM
NSC's Avatar
NSC
2nd Gear
Thanks for the response. Does a dealer have to do this ?
Old Feb 25, 2019 | 08:25 AM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
I strongly recommend you check the "in Service" date for this car. If it was put in service less than 5 years ago, the drivetrain is still covered by the 60 month, 100,000 mile warranty. I'd take it to a dealer today to find out. You will have to pay for the routine service of the transmission, but any non-routine maintenance may be covered by the factory warranty.
To Automatic transmission problem
