Adding amp and replacing dash speakers
Old Mar 14, 2019 | 12:03 AM
Matthewstorm's Avatar
Matthewstorm
Default Adding amp and replacing dash speakers
I'm looking to add an AMP and replace my dash speakers and looking for some good recommendations. I'll also be using the Pac-Audio AMP Pro4. Thanks.
Old Mar 17, 2019 | 10:50 AM
Matthewstorm
No one?
Old Mar 17, 2019 | 11:03 AM
ZO6 cracker's Avatar
ZO6 cracker
I have been also doing a lot of research on this. Don’t seem to be a lot of installs done on the C7. I want to do the crazy cowboy sound deadening also but I’m trying to find out from someone that did the install kit and then went back later on to do the audio install.
Old Mar 17, 2019 | 11:06 AM
Matthewstorm
Yeah. I'm not seeing a lot of C7 installs, either. When I replaced my speakers I added sound deadening and I think it made a big difference. Not the Cowboy stuff. But now that I'm thinking of adding a more powerful amp and dash speakers I'd like to get a little advice.
Old Mar 17, 2019 | 11:11 AM
ZO6 cracker
When I had my C5 Z06 I had a awesome system in it with the sound deadening. I plan on having my audio guy do my install down the road. Did you add your speakers and sounddeadening yourself? How does it sound now? What do you have now in your car?
Old Mar 17, 2019 | 12:24 PM
Matthewstorm
I replaced my door speakers and rear 8" sub. The sound is drastically better but it still lacks power. I bought sound deadening off Amazon, had a good rating. My installer did everything. Cost $200. It'll probably be close to 1K for amp, PAC-Audio, and install, and hopefully also dash speakers. I have no idea which way to go there, tho.
Old Mar 17, 2019 | 12:46 PM
ZO6 cracker
Yeah you definitely need a good amp. I don’t like that there are subs in the doors. I will be looking at having adapter plates made for my doors and going with 6.5 component set. Mine does not have the sub in the back. I found a setup that another guy did and it came recommended from Doubledmods when Dennis first starting doing the C7. I think that will definitely be a good way to go.
Old Mar 17, 2019 | 04:10 PM
Matthewstorm
Which setup is that?
Old Mar 17, 2019 | 04:45 PM
2016C7.paul's Avatar
2016C7.paul
https://www.corvetteforum.com/forums...e-project.html
To Adding amp and replacing dash speakers
