Mice
Old Apr 29, 2019 | 11:28 PM
DMASSO's Avatar
DMASSO
5th Gear
Default Mice
Cabin filter and nest material.
Took my 2016 C7 out for a ride before rain all week. Has been in.my spare garage. Car had a funny smell. I looked at the cabin filter. Mice ate right through it and made a nest
Popular Reply
Apr 30, 2019, 08:58 AM
The Creeper's Avatar
The Creeper
Get a cat!
Old Apr 29, 2019 | 11:36 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Check your wiring. They like to eat the wire covering.
Old Apr 30, 2019 | 07:52 AM
Hopefully you found this before they could do any other damage.
Old Apr 30, 2019 | 08:05 AM
rogergcam's Avatar
rogergcam
That is exactly what they did to my ZO6!
I never saw any signs of mice-no droppings-anything!
FWIW I now have traps around the garage (still haven't caught any mice) and two dishes of mothballs under the car! Hopefully, the smell keeps them away! I also pop the hood-the idea being that mice like dark places to work in, and the open hood does away with the dark!
GOOD LUCK!
Old Apr 30, 2019 | 08:16 AM
fake's Avatar
fake
You better do something quick because i had a problem and once they move in it is a night mare. First leave hood open to cool motor before covering with cover! Second buy the bait from your local grange store and use the black traps with the greenbait inside. You can monitor there eating by seeing broken pieces of bate near the trap entry. Also always open the hood before starting to see if any other damage has been done and to replace the traps.
Old Apr 30, 2019 | 08:58 AM
The Creeper
Get a cat!
Old Apr 30, 2019 | 10:55 AM
RMS73's Avatar
RMS73
I added some house door foam weather stripping around the filter compartment opening for a better seal with the covering door. I also leave the hood up. Put an ultrasonic device with a light beside the car to try to keep the mice away.
Old Apr 30, 2019 | 11:17 AM
KurtsZ06's Avatar
KurtsZ06
Maybe an old tale, but I’ve heard over and over that mice can’t stand neon lamps. I keep neon lamps on in my garage as well as my attic 24/7. Never ever had a rat or mice problem. Next door neighbor told me last year that mice ate the insulation on his 2014 Porsche Turbo main harness. Another neighbor said he had a rat problem in his attic.
Works KS for me.
Old Apr 30, 2019 | 11:27 AM
V Vette's Avatar
V Vette
Originally Posted by The Creeper
Get a cat!
Or two!
Old Apr 30, 2019 | 11:28 AM
Maxpowers's Avatar
Maxpowers
Does anyone remember the name of the supporting vendor that specialized in rodent control? They used some sort of strobe light effect.
Old Apr 30, 2019 | 11:40 AM
orca1946's Avatar
orca1946
Sticky traps - then you can see what is eating your car!!
Old Apr 30, 2019 | 12:00 PM
rogergcam's Avatar
rogergcam
Default sticky things
I put out some sticky traps also. All they did was catch a bunch of Gheckos! Gheckos are good little things as they eat all kinds of bugs! I took the sticky traps out real fast!
Old Apr 30, 2019 | 12:05 PM
lemo's Avatar
lemo
They actually don't eat the wiring as much as back in the day. Apparently the coating covering the wires in the past use to have soy bean in it and was the reason why they use to chew the wiring up all the time. Now they just chew it if its in the way of where they want to go or get to.
Old Apr 30, 2019 | 12:54 PM
Mr. Jones's Avatar
Mr. Jones
I have a car in long term storage far from home.
I go there about every month.
I had mice in the engine compartment and fender.
I needed a trap that could site for a month without leaving a stinking mess.
I used a 5 gallon pail, put about 2" of anti-freeze in it.
Put a rod thru the top edge center with a beer can centered on the rod.
Put a piece of wood for a ramp to the top of the pail.
Put peanut butter on the can.
The mice go up the ramp, jump to the can
the can rotates and the mice fall in the anti-freeze.
one month and five mice later I was done.
Found the trap on the web.
The mice were getting in the garage by chewing the rubber seal on the sides by the door.
I glued strips of metal (roof flashing) to the rubber, about 2" x 1" at each lower end of the door seal.
No mice for two years.
Old Apr 30, 2019 | 12:58 PM
Matthewstorm's Avatar
Matthewstorm
Were you able to save the Gecko's? GEICO is watching you.
Old Apr 30, 2019 | 01:08 PM
Rebel Yell's Avatar
Rebel Yell
Must have been cousins to my critters. They built a nice abode in my filter also. I keep traps, and bait in my garage nearly all of the time.
Old Apr 30, 2019 | 01:52 PM
dvilin's Avatar
dvilin
To Mice
Old Apr 30, 2019 | 02:22 PM
Zjoe6's Avatar
Zjoe6
Moderator
There’s a really old trap that is basically a box made out of galvanized sheet metal. It has a tunnel that goes through the center and the rodent gets scooped and pushes into the box. No bait needed. Just wind it up now and then. I always keep one in my garage.
Old Apr 30, 2019 | 04:36 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
This 12" rat is what I found, after 10 days, wedged in my windshield wiper motor....
Old Apr 30, 2019 | 05:28 PM
eseibel67's Avatar
eseibel67
I keep the car in a storage unit for 5 winter months and mice are my only fear. I needed a solution that doesn't require periodic intervention. I read on this site that mice do not like the smell of peppermint.
I prepared 2 empty margarine containers. Drilled four 1/4 inch holes in the lids. Inserted egg-sized sponges inside, saturated them with peppermint oil and closed the lids. Placed them on the ground, one under the engine compartment fuse box and the other under the mufflers. No mice this past winter so will do same next year.
