Help needed - need a new engine
Old Oct 31, 2019 | 03:36 PM
s n v f f's Avatar
s n v f f
Default Help needed - need a new engine
Hello Guys,
i had a serious engine problem involving pistons, valves and other parts.
I do have a 2014 C7 Z51 package manual 7 transmission.
I need to buy an LT1 engine crate to replace my whole block.
Can you please tell me, or better link me where to get it?
i want a new engine, not refurbished or so.
Thanks alot
Alessio
Old Oct 31, 2019 | 03:52 PM
Red08's Avatar
Red08
Originally Posted by s n v f f
Hello Guys,
Thanks alot
Alessio
You need to tell us more about the engine that needs replacing. How many miles on the car? Are you the original owner, and if not, how many owners have there been previous to you? Has everything been serviced regularly as it should be? How has the car been driven over the years?
Old Oct 31, 2019 | 04:13 PM
Pete43's Avatar
Pete43
Just google" LT1 crate motor"
Old Oct 31, 2019 | 04:18 PM
robert miller's Avatar
robert miller
Default ttt
Just buy your self the new short block then have your heads put on to the block. P.S. if you use your old dry sump set up YOU better pull of the car that full system & have it really really cleaned & gone thur if any small piece's of metal got into the pan..... Robert
www.SCOGGINDICKEY.COM
They are a vendor in here also.
Old Oct 31, 2019 | 04:40 PM
s n v f f's Avatar
s n v f f
this should be the correct one, do you guys confirm? dry sump LT1, i have a 2014 Z51 manual transmission
Old Oct 31, 2019 | 05:13 PM
robert miller
Default ttt
Just make sure also YOU remember down the road which water pump this new motor has on it. 2014 was a pig in a pock thing the 2014 is all by itself & if you do anything on add ons you will have to remember with water this new motor is using. Cause if you just tell them 2014 & this new motor is using the 2015 newer water pump parts will not fit..
But you will be good as long as you don't do any blower set up & that type of stuff... Robert
Old Oct 31, 2019 | 07:47 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
https://www.corvetteforum.com/forums...ly-8000-a.html.
Just buy this and call it a day.
Old Oct 31, 2019 | 07:59 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
C’mon, tell us how you destroyed it. It must be a good story.
Old Oct 31, 2019 | 08:18 PM
s n v f f's Avatar
s n v f f
Guys, really I need help.
can someone confirm me if this is the correct engine for the 2014 Z51? code number 19329997
thanks
Old Oct 31, 2019 | 08:34 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
Why put an OEM engine back in? Get something better at a better price.
That Katech engine is a great value.
Contact TSP - they can also help you
https://www.texas-speed.com
Old Oct 31, 2019 | 08:53 PM
Grip Grip's Avatar
Grip Grip
Originally Posted by 2000FRCZ19
The ad states it has "GM pistons & Mahle rings". Does that mean stock LT1 pistons or LT4 that can take some abuse? I completely agree with the idea though, don't buy stock if a solid rebuilt and upgraded motor is available for a great price.
Old Oct 31, 2019 | 09:51 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
call jason at katech he can give you all the info on it. They know what they are doing when it comes to building power. You can pm him on here too. He can help you out with what you want or need as well as Texas speed.
Old Nov 1, 2019 | 03:53 PM
Red08's Avatar
Red08
I agree. I and others would like to know what happened to need a new engine.
Old Nov 1, 2019 | 03:59 PM
24/Eray's Avatar
24/Eray
Where you located? If within an hour or two of Tune Time Perfornace in Lakewood. That's my buddy's shop. He has all kinds of things... and a five axis cnc machine etc.
He's down the block from Jessel.
Old Nov 1, 2019 | 08:27 PM
2019Vette's Avatar
2019Vette
Didn’t you just put up a load of videos after 5 different tunes .... end result pops bangs and flames?
what happened.
Old Nov 4, 2019 | 02:16 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
The stock pistons are sufficient for that power level. If you're going to be racing it or upping the power level forged pistons would be in order. LT4 pistons are a different story and quite incredible what they can handle. We ran a stock LT5 engine (same as LT4 pistons) to 1486hp before we bent a connecting rod.
__________________
Contact:
(e) zach@katechengines.com
Old Nov 4, 2019 | 03:21 PM
Jeff V.'s Avatar
Jeff V.
He's in Italy.
To Help needed - need a new engine
