Tires
Old Dec 31, 2019 | 06:20 AM
Keiths1969's Avatar
Keiths1969
Default Tires
Need some assistance please, I clearly do not understand all the different types of tires available for a 2016 Z06. I continue to get different responses from local tire dealers.
I live in Georgia and need to replace my factory tires (vehicle only has 10,000 miles). Can someone offer some advice?
No track use
Looking for year round type of tires
Old Dec 31, 2019 | 06:37 AM
saleen556's Avatar
saleen556
AS3 plus is the best all season tire available. Many of us are extremely happy with them.
Old Dec 31, 2019 | 06:59 AM
Keiths1969's Avatar
Keiths1969
Thank you but are you referring to Michelin Pilot Sport A/S 3 Plus?
Old Dec 31, 2019 | 07:03 AM
saleen556's Avatar
saleen556
Yes👍🏻
Old Dec 31, 2019 | 11:05 AM
xWS6guy's Avatar
xWS6guy
I asked a similar question a few weeks ago, and I also have a 2016 Z06. There aren't a ton of options to consider. Here is the best concise answer I received from another poster:
Cup 2 noisy- great summer tire and track day tire if no rain
super sports- not noisy, great summer and track day tire if light rain
as3+ - not noisy, slight less grip at limits, better in rain and cold
r888r- ultimate street dry tire, not as good as cup 2 on track when cup 2 is new and hot. Doesn’t come in factory sizes.
continentals- good daily tire, not noisy, not run flat, runs narrow and changes “look” of tire fitment.
Old Dec 31, 2019 | 11:59 AM
Keiths1969's Avatar
Keiths1969
Which did you end of buying?
Thanks in advance
Old Dec 31, 2019 | 12:07 PM
I Fly Low's Avatar
I Fly Low
Good summary. Spring Mountain recommends the AS3+ I went with the continental, hoping to get a bit longer wear. They feel a little harder and there is noticeably less grip than the Super Sports. They don't looka s aggressive either. They are lasting longer, which is a plus.
Old Dec 31, 2019 | 12:13 PM
Bill Dearborn's Avatar
Bill Dearborn
Have you checked out what a Discount Tire store near you might have? A lot of small shops and local tire stores may not have the proper equipment to mount new tires on your rims and that will bias what they tell you.
Bill
Old Dec 31, 2019 | 01:00 PM
Keiths1969's Avatar
Keiths1969
I did Bill and they were the ones who confused me with the different types and styles. The forum offered some good advice.
Old Dec 31, 2019 | 01:11 PM
xWS6guy's Avatar
xWS6guy
Thanks in advance
I stuck with the Super Sports. I live in Phoenix, so I didn't feel the need to get the all weather tires. If you frequently drive in the rain, the AS/3 would be a good choice, and would probably save you about $400 over the factory option.
Another thing to look for is the wear on your existing tires. My car was close to factory spec on alignment, but it still chewed up the insides of both the front and the rear (more so the front). I would have gotten quite a few more miles with a less aggressive setup. I had an alignment done immediately after getting the tires put on and am hoping to do better this time. I made it 12,000 miles, but the fronts were well past done and should have been replaced sooner. I honestly wouldn't have known how badly they were worn if I hadn't crawled under the car to do something unrelated. I couldn't see anything looking directly at the tires with the car being so low and the location of the wear.
Old Dec 31, 2019 | 04:08 PM
Gould1's Avatar
Gould1
Do they make a Super Sport in Non Run Flat?
Old Dec 31, 2019 | 06:43 PM
xWS6guy's Avatar
xWS6guy
Not that I'm aware of.
I considered a non-run flat, but I drive into some pretty desolate areas on twisty mountains roads and decided I didn't want to roll the dice on something like that. The situation may be much different for others.
Old Dec 31, 2019 | 06:55 PM
mbaessler's Avatar
mbaessler
I see you live in San Diego so there is no reason for AS3+'s (not cold very often). Why not stick with the Super Sports or the New Piolt 4's?
Old Jan 1, 2020 | 02:17 AM
Grand Slam's Avatar
Grand Slam
^^ AS3+ are much better on wet pavement than the OEM tires.
Old Jan 1, 2020 | 09:19 AM
Keiths1969's Avatar
Keiths1969
Thanks for all the input and advice. Believe it or not the information shared on here is more valuable than what tends to be said at the shops.
Old Jan 1, 2020 | 09:26 AM
BELVIN20's Avatar
BELVIN20
I have the Michelin AS3+ on my 2016 Z for the last 12k miles, & I think they are the best. I do not track, so I was looking for long wear, less noise, and the ability to drive the Z in cold & wet conditions, and the AS3+ does it all. What ever tire you get, get at street alignment, as close to Zero toe as you can get to get max tire life.
Old Jan 1, 2020 | 09:28 AM
bjones7131's Avatar
bjones7131
Since the continental fitment looks different would love to see a pic of one mounted. This is the tire I am leaning toward when time comes. Anyone willing to take a pic and post. Thanks
To Tires
Old Jan 2, 2020 | 12:33 AM
IAIA's Avatar
IAIA
I had Pilot Sport 4S's on my C6 Z06 and want them on my C7 GS, but they apparently are not made--at least not in Tire Rack, America's Tire, or Costco. Are they available?
If not, I"m thinking the PSS's and not run flats (hate run flats and don't need them in southern CA). AS3's a few $100's cheaper than Super Sports, but I think they don't perform as well in dry? I don't track the car.
Old Jan 2, 2020 | 09:01 AM
Gould1's Avatar
Gould1
I asked the question about PSS in a non run flat and I don't believe they make them...
Old Jan 2, 2020 | 09:03 AM
Elk's Avatar
Elk
The Pilot Sport A/S 3 Plus do not perform as well in the dry, but many are satisfied with the level of performance they provide.
