Non-NPP
Old Feb 27, 2020 | 09:21 AM
Jerrys-1LT's Avatar
Jerrys-1LT
Originally Posted by BillyC7
I had the same problem with my non NPP. I could not continue with the Cadillac sound on a Vette. After much research I chose the AWE afm valve back system. Corsa does make a similar system at a higher price. Yes it is quite loud and obnoxious. However, it has the 180 degree drone elimination and does work. The tire noise is louder. I found that using manual to hold a higher gear with lower revs keeps the sound down when needed. Actually it is like driving a new car, hearing the shifts, using manual deceleration to produce burbles - lots of fun! Also will not void warranty or cause emission test failure. look up CSP for system, prompt shipping no charge. Costs me $330 for install at the best Corvette shop in area.
Second this opinion. I had the same exhaust installed on my car. Since I like early morning drives, I keep my shifts at less than 1500 rpm while in my housing development. It comes alive at about 2500 rpm. I got the black tips on my blade silver and the appearance is awesome.
