Push-button Start/Stop?
Old Mar 27, 2020 | 12:56 PM
Tin-can's Avatar
Tin-can
Default Push-button Start/Stop?
I’ve heard stories of people taking their keys and leaving running vehicles (with push-button start) without pushing the start/stop button. While the door may lock automatically after the programmed delay, will the engine shut off, or will the engine run until the gas tank is empty?
I can’t find anything in the manual and wonder if anyone here on the forum has either experience or solid knowledge of this situation.
Old Mar 27, 2020 | 01:32 PM
Flame Red's Avatar
Flame Red
Engine will run until you turn off the engine, or it runs out of gas, or you drive off without the fob and then your destination and go to restart and you cannot restart because you left your fob..
Old Mar 27, 2020 | 02:52 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I live my life by 3 simple rules:
1) When I leave home in my 'vette, the FOB NEVER leaves my pocket
2) Never share everything you know
3)
Old Mar 27, 2020 | 02:57 PM
badhabit_wb's Avatar
badhabit_wb
If I start mine, lock the doors, and walk away it shuts down in just a few minutes. That's if the fob is not in the car but in my pocket. My car is a 19.
Old Mar 27, 2020 | 03:08 PM
c54u's Avatar
c54u
From the 2017 manual - maybe other years will be different .... look under Extended parking.
Extended Parking
If the vehicle is left in P (Park) while
running and the Remote Keyless
Entry (RKE) transmitter is outside
the vehicle, the vehicle will turn off
after one hour.
running and the RKE transmitter is
inside, the vehicle will run for two
hours
. At the end of the second
hour, the vehicle will turn off.
The timer will reset if the vehicle is
taken out of P (Park) while it is
running.
Old Mar 27, 2020 | 04:03 PM
badhabit_wb
Mine is an m7 but I think it shut off in less than 15 minutes with the fob away from the car and parking brake set.
Old Mar 27, 2020 | 04:10 PM
4thC4at60's Avatar
4thC4at60
My '15 MN7 would shut off in an hour - had that happen a couple of times. I'd leave the car running in safe location to keep the car cool inside because it was August and hot as hell here in Texas. I was surprised the first time to come out to find the engine off. Forgot about it the second time, but knew what had happened.
Old Mar 27, 2020 | 04:28 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
My 14 appears to not have any time limits on it for running w/o a FOB in the car. It makes no mention of extended parking in the Owner's Manual.
Elmer
Old Mar 27, 2020 | 04:57 PM
Interesting thread. I have a ‘14 also but have never found myself in the situation described by the OP.
Old Mar 27, 2020 | 07:49 PM
SecondWind's Avatar
SecondWind
I often thought a nice feature would be a programmable delay one could set before the engine shut down with no fob present. Might be useful if you got car jacked.
Old Mar 27, 2020 | 08:26 PM
Mad*Max's Avatar
Mad*Max
If you leave the fob in with the engine running and walk away it will honk at you to remind you!
Old Mar 27, 2020 | 08:44 PM
c54u's Avatar
c54u
You can turn this feature off in the settings screen.
Remote Left in Vehicle Alert
This feature sounds an alert when
the RKE transmitter is left in the
vehicle.
Select Off or On.
Old Mar 27, 2020 | 09:12 PM
silver19's Avatar
silver19
2019 manual says turns off after 1/2 hour if the RKE is outside the car and 1 hour if the RKE is inside the car
Old Mar 27, 2020 | 09:21 PM
Mad*Max's Avatar
Mad*Max
vehicle.
Select Off or On.
isn't that only for when the car is off and you leave the fob inside?
Old Mar 27, 2020 | 09:36 PM
c54u's Avatar
c54u
I know, that my 2017 did not honk if it was left running and I left the fob in the car.....but I did have to have a software update done to the infotainment system late last year. I will have to test this again.
Old Mar 27, 2020 | 09:55 PM
Mad*Max's Avatar
Mad*Max
I will double check my 2019, I know my two other GM vehicles honk for sure.
Old Mar 28, 2020 | 08:30 AM
Mad*Max's Avatar
Mad*Max
I tested mine this morning and it honked
Old Mar 28, 2020 | 09:22 AM
RPK's Avatar
RPK
Agreed. Mine was in the drive while I was working in the garage.
It shut off within 15 minutes.
Old Mar 28, 2020 | 10:22 AM
c54u's Avatar
c54u
I tested mine this morning as well and it did honk.
To Push-button Start/Stop?
