How soon did you replace the diff fluid?
Old Jun 4, 2020 | 06:51 AM
  #41
NashvilleGrandSport's Avatar
NashvilleGrandSport
Had mine done at an independent shop at 8k miles. Probably not needed as fluid looked good, but did it for peace of mind. Car had one abbreviated track day.
Old Jun 4, 2020 | 07:14 AM
  #42
Cman01's Avatar
Cman01
I just did my axle fluid swap couple weeks ago around 1100 miles, the fluid came out dark and kinda yucky so glad that I changed it out.
I will run it another 2-3k then change it again and also change the trans fluid at that time.
Tony
Old Jun 4, 2020 | 12:07 PM
  #43
Dallas007's Avatar
Dallas007
I did mine myself without any jacks or ramps and it was easy. I did use a swivel head ratchet. I had 1500 miles and had quite a build up of debris on plug. I was also almost a quart low. Put GM fluid back in. Good luck!!
Old Jun 4, 2020 | 06:31 PM
  #44
Red08's Avatar
Red08
Thanks guys for the input. I'm going to get a swivel head for my 3/8" ratchet and do mine soon.
Old Jun 5, 2020 | 05:01 PM
  #45
javenius's Avatar
javenius
Purchased 2019 GS with A8 trans in November 2018.
My salesman recommended changing the rear diff at 1000 miles. Followed his advice. Fluid was silvery but not too bad. However, encountered under fill condition from the factory (frequent finding). Drained 74 oz and put in 85 oz. Easy job to do if you have access to the bottom of the car.
Also, had my A8 trans fluid triple flushed at 5000 miles when new fluid was released. Much smoother shifts.
Old Jun 5, 2020 | 05:12 PM
  #46
MMD's Avatar
MMD
Think you made a wise choice. I have done the same. I had to replace my OEM tires at 11,000 miles. I also updated my Navigation map. I too have a 19 GS. There have been too many road changes recently in my state so I thought it wise to do.
Old Jun 5, 2020 | 07:22 PM
  #47
Litfuse's Avatar
Litfuse
A friend of mine builds custom differentials for hardcore off-road vehicles. He recommends first change at 500 miles to remove all the metal shavings.
Amsoil recommends no earlier than 4,000 miles on differentials as a second view point.
Old Jun 6, 2020 | 11:26 AM
  #48
Cassavette's Avatar
Cassavette
8th Gear
I would follow the service schedule in the owners manual.
Old Jun 6, 2020 | 04:04 PM
  #49
Red08's Avatar
Red08
I ordered GM OEM diff fluid today, and went out and bought a 3/8" swivel head ratchet. Diff fluid was $16 / quart. I ordered GM part # 88862624, which contains a friction modifier. I changed the diff fluid in my C6 several years ago and it was a very easy job.
