How soon did you replace the diff fluid?
Old Jun 2, 2020 | 06:21 PM
Red08's Avatar
Red08
Default How soon did you replace the diff fluid?
I have seen some YouTube videos where guys changed their diff fluids relatively soon. (less than 5,000 miles) I'm curious how soon some of you changed yours.
Old Jun 2, 2020 | 06:32 PM
MichaelO's Avatar
MichaelO
Default Did mine a few weeks ago
7200 miles on my 2017 GS A8. Did not look too bad but glad it's done. Easy to do myself.
Last edited by MichaelO; Jun 3, 2020 at 05:23 AM. Reason: added a comment on ease to do.
Old Jun 2, 2020 | 07:04 PM
PWRWAGN's Avatar
PWRWAGN
How difficult is this to do? I have a 2017 Z06 with 14k miles on its way and was thinking this should be done.
Old Jun 2, 2020 | 07:11 PM
redman76's Avatar
redman76
St. Jude Donor '09
I changed mine with a few thousand miles on it. It's fairly easy to do, just need a swivel head ratchet and a hand pump to push the new gear lube in. I believe there is a how to article in the How-To sticky section at the top of the C7 General forum.
Old Jun 2, 2020 | 07:15 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
I always do it between 1,500 and 2,000 miles on the Camaro's and Vettes. Get the junk out. Pretty easy job!
Old Jun 2, 2020 | 07:20 PM
4thC4at60's Avatar
4thC4at60
For 30 years I have followed the service recommendations in the owner's manual. In that time I have amassed almost 900,000 miles in Corvettes - my '15 C7 had 96,000+ miles on it when I traded it for my '19)..... none of my cars ever suffered anything worse than a failed alternator - guess I forget to lube it, huh?
I followed the same recommendations on all the BMWs, MBs, Audis, and other cars too.... and, that's the procedure I follow for the Ferrari as well... must work, no?
Old Jun 2, 2020 | 07:23 PM
MMD's Avatar
MMD
First one at 500 miles. Next at 5K, next at 10K. I'm on my 3rd differential.
Old Jun 2, 2020 | 07:27 PM
beaversstonehaven's Avatar
beaversstonehaven
Going to have it done at my next oil change right at the 30,000 mile oil change.
Base Stingray coupe 1lt.
Old Jun 2, 2020 | 07:29 PM
phalse's Avatar
phalse
Rear sway bar kinda gets in the way, otherwise it's exactly what it appears to be. I did mine just cuz I had mine in the shop for the trans fluid.
Old Jun 2, 2020 | 09:43 PM
Dennis Bernal's Avatar
Dennis Bernal
Does the service manual state it needs to be changed?
I have seen people say that the diff fluid from the factory is not good, but with no substantive or even objective data stating as to why it is not desired.
My car seems to shift and drive fine ('15 Z51 M7), but I do love maintenance stuff. (Did air filter today, cabin filter yesterday).
Even though I like it, yanking the fluid for no reason seems like a waste.
Any additional data or links would be great if anyone has any.
Old Jun 2, 2020 | 09:58 PM
MMD's Avatar
MMD
Old Jun 2, 2020 | 10:37 PM
MMD's Avatar
MMD
From the 2019 GS Owners Manual. Should be the same from 2014-2019
Old Jun 2, 2020 | 10:39 PM
Matthewstorm's Avatar
Matthewstorm
Changed mine at 40,000. Boy, was it expensive.
Old Jun 2, 2020 | 10:47 PM
MMD's Avatar
MMD
It's easy to do. Save yourself some coin and do it yourself.
Old Jun 2, 2020 | 10:48 PM
Matthewstorm
No way to lift my car that high.
Old Jun 2, 2020 | 10:53 PM
Dennis Bernal
I've watched the YoutTube video when it was published... I didn't see anything that pointed to a knowledgeable person pointing out any issues with the OEM rear diff fluid.
Thanks for the reminder that it is in the service manual. I have been sticking to that manual to the "T". I will continue to do so.
Just did coolant swap, cabin and engine filter over the last couple days.
Old Jun 2, 2020 | 11:23 PM
devnull's Avatar
devnull
Some change it early, others don’t. Some track and some don’t. Many like to dump the dirty stuff out anyway.
Is it required like the Camaro track addendum? No, but still not a bad idea. I wouldn’t worry about it if you follow the manual but for me, I change early.
i also have a lift so these things are very easy and that factors into these types of decisions.
To How soon did you replace the diff fluid?
Old Jun 2, 2020 | 11:29 PM
MMD's Avatar
MMD
You don't need to put it on a lift. All you need is a hand jack, 2 race ramp, Corvette frame pucks (2), hand tools to remove plug, fluid transfer pump. All these, except the pucks, can be had at Harbor Freight.
Watch this vid
Old Jun 2, 2020 | 11:44 PM
G8ME's Avatar
G8ME
I did mine this past Sunday while I changed out my exhaust to a Borla exhaust. My Vette only has 16,000 miles on it and the differential you would have thought it had 50,000 miles on it the way it looked.
Old Jun 2, 2020 | 11:51 PM
MMD's Avatar
MMD
Some forum members have stated that most of the junk found in the diff oil develops in the first 1000 miles during it's break in.
