Adding navigation
Old Jun 5, 2020 | 02:04 PM
bnkvette's Avatar
bnkvette
Veteran: Marine Corps
Default Adding navigation
Can NAV be added to info screen? Has anyone done it? What is the cost?
Old Jun 5, 2020 | 02:25 PM
defaria's Avatar
defaria
My understanding is A LOT - like $1200 or so. I think you can just use Android Auto/CarPlay instead. They are better navigation systems anyway.
Old Jun 5, 2020 | 02:35 PM
Akcajunz's Avatar
Akcajunz
Veteran: Coast Guard
My understanding of the GM Nav system is that its ancient and expensive and needs updating from time to time(at a cost). I use the CarPlay app in my car. No updates ever required and google maps is good as well as Waze. I use Waze when on the interstates. Google maps is more detailed for in City use. Good Luck with your choice.
Old Jun 5, 2020 | 02:44 PM
pll's Avatar
pll
6th Gear
How to have Carplay on a 2015?
Old Jun 5, 2020 | 02:54 PM
Da Hawk's Avatar
Da Hawk
GM Navigation just sucks. Complete waste of money for me. I've used it just to try it out and see how reliable it is. It always takes me on routes that are much longer than needed even when I know there might be a quicker route. Pfffttt…. Also, it doesn't make any financial sense to pay for the Nav updates from GM when you can use Google Maps or similar phone apps for free. They are more reliable and accurate.
Old Jun 5, 2020 | 02:57 PM
Da Hawk's Avatar
Da Hawk
Look into this. Some forum members have added this. It's on my list for my 2014 3LT Z51 that was "fortunate" to have the GM Nav instead.
https://www.gm-navigation.com/gm-navs/
Old Jun 5, 2020 | 03:15 PM
Pablotheartist's Avatar
Pablotheartist
https://www.ebay.com/itm/174019993683
i just purchased this kit on ebay. Should be here on monday. Without nav and just carplay is $699
Old Jun 5, 2020 | 03:23 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Aftermarket sells the HMI that will add the NAV and the GPS. Fairly easy to do too.
Video how to: https://www.corvetteforum.com/forums...post1591904544
MVI https://www.gm-navigation.com/ and Anthony 919 995 9523
Elmer
Old Jun 5, 2020 | 03:50 PM
Mister Big's Avatar
Mister Big
I did the upgrade and it was a simple install. I did run into a problem when I took the car in for the Android update (this was back in mid-2016 when the system needed to be updated to enable Android). After the software update, navigation was no longer operational and I had to send the HMI unit back the the e-bay seller to have it re-flashed.
Old Jun 5, 2020 | 04:47 PM
pll's Avatar
pll
6th Gear
"Plug and Play Installation ( due to the nature of where the modules are located in the Corvette, this is an advanced time-consuming install )"
That discourage me, will continue with the iphone on a support in front of the screen and spend this money on gas!
Thanks anyway for the info!
Old Jun 5, 2020 | 05:31 PM
JMII's Avatar
JMII
https://www.infotainment.com/product...d-auto-upgrade
$1400 you get CarPlay + Nav... so yeah not cheap. You can piece it together yourself much cheaper via eBay, but you will need the HMI module programmed to your VIN.
The link above has a video showing you the steps, its not that bad. I've pulled both the HMI and radio module to do some troubling shooting so got a feel for the work involved.
Old Jun 5, 2020 | 06:38 PM
bnkvette's Avatar
bnkvette
Thanks for the info
Old Jun 5, 2020 | 06:53 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Just use Waze, a much better GPS, it's free, and works great, plus people input police and accidents that you are driving into, and counts down the mileage to that area.
Much better than any GPS out there on the market!
Old Jun 5, 2020 | 06:57 PM
eboggs_jkvl
Moderator emeritus
And that depends on what year Corvette he has. Since he doesn't mention the year car, he might not have the option to use Waze, or carplay or etc....
Elmer
Old Jun 5, 2020 | 07:14 PM
jimmbbo's Avatar
jimmbbo
If you have the Homelink visor garage door opener, one thing to remember is to reattach the power connector for the opener or you'll get some practice disassembling the trim again... Don't ask how I know...
Old Jun 5, 2020 | 08:38 PM
Dcasole's Avatar
Dcasole
JIMBO ?? Maybe wrong forum ?
Old Jun 6, 2020 | 01:54 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
Don't quote me, but I think there's a way to link navigation on your phone, and have it show on your display. May only apply to later versions though.
Old Jun 6, 2020 | 02:01 PM
eboggs_jkvl
Moderator emeritus
Not really. Setting the font to gray sucks there fella.
Elmer
To Adding navigation
