Tire Pressure
Old Aug 16, 2020 | 03:12 AM
  #61
lostsoul's Avatar
lostsoul
Banned Scam/Spammer
ok.. ok.. Im confused... so lets say..
I'm out in santa cruz.. inflate my tires to 30psi
THEN
: pick up a fat chick weighing 325lbs
: Cruse to Yosemite w/ 12K elevation
: 105 Deg w/ 80% humidity
: Then while driving I accidentally roll into a 3 foot deep puddle submerging the tire...
What would be the correct TPMS reading?
Old Aug 16, 2020 | 01:55 PM
  #62
AZ99FRC's Avatar
AZ99FRC
THEN
That depends. What is the fat chick wearing?
Old Aug 16, 2020 | 05:20 PM
  #63
Crossed Flags Fan's Avatar
Crossed Flags Fan
Nada.....
Old Aug 16, 2020 | 08:05 PM
  #64
BigBoyRon's Avatar
BigBoyRon
I would predict the TPMS reading will be 27.5.
Old Aug 17, 2020 | 05:27 AM
  #65
lavla's Avatar
lavla
Hey, if GM says 30PSI, I'll go with that. On the other hand, I've already had to replace wheels because of the bent/cracked wheel issue. My question is, "Is there a better PSI to set so that there is less stress on the wheels (OEM wheels)?". Just asking, no flames please.
Old Aug 17, 2020 | 09:40 AM
  #66
6Speeder's Avatar
6Speeder
I wouldn't change air pressure based on fears of bent wheels. The tires are so stiff being run flats that small changes in pressure won't help the stress the wheels are facing. Go with whatever cold pressures give you the best tire wear and call it a day.
My opinion: Unless you are running the car REALLY hard, or racing, and are still running the stock tires/wheels/suspension pieces, go with 30 PSI cold.
Old Aug 17, 2020 | 10:24 AM
  #67
Navy01Coupe's Avatar
Navy01Coupe
30 PSI cold. Got it.
But this week it is 96 degrees in my garage. So, COLD is a relative term.
Old Aug 17, 2020 | 10:43 AM
  #68
JMII's Avatar
JMII
A few PSI here or there is not going to cause problems. You don't need NASA levels of precision on a street driven vehicle. The most important thing is to check your air pressure often as tires lose air over time. So if your like the average 'Vette owner and you don't drive many miles you might be in for a surprise the next time you pull the car of out of the garage.
Old Aug 17, 2020 | 10:59 AM
  #69
BigBoyRon's Avatar
BigBoyRon
and that is parked in the shade!
Old Aug 17, 2020 | 11:28 AM
  #70
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
My Vette winters for about 6 months a year. It is in a unheated but under house garage and the coldest I have seen garage go is 38. The outside temperatures been known to go down to -28F at night. Sub zeros for a week at a time are normal up here! (upper NYS)
I raise the tire pressures to about 33 when I put it away, and normally I have about 30 PSI in them in April when I activate the car. This is over 4 Vettes in a 22 year period, so for me this is a sort of constant.
Old Aug 17, 2020 | 02:19 PM
  #71
Elk's Avatar
Elk
It certainly is in your case.
But ambient temperature is ambient temperature. If you are typically driving when it is 90 degrees, set the air pressure to 30 psi when the "cold" temperature is 90. You may well end up leaving air out of your tires.
Hang in there!
Old Aug 17, 2020 | 03:31 PM
  #72
Vet Interested's Avatar
Vet Interested
Four pages on tire pressure. Impressive!
Old Aug 17, 2020 | 03:40 PM
  #73
MMD's Avatar
MMD
Ask Kev Jones opinion. He should be able to get you within + or - 5 psi of what you need. Think he said he has a degree in air pressure technology.
Old Aug 17, 2020 | 04:55 PM
  #74
madrob2020's Avatar
madrob2020
HOT AIR or air pressure? Just kidding!
Old Aug 17, 2020 | 05:12 PM
  #75
Navy01Coupe
This might be my new favorite Forum string.
Old May 25, 2021 | 05:34 PM
  #76
Bird67's Avatar
Bird67
Resurrecting this thread to pose a specific question. In this thread it seems like 30 psi cold is a consensus proper air level. That is also what is on the tag inside the driver door.
Question: does anyone think that should change if I have swapped out the OEM summer only tires for Pilot Sport A/S 3+? Mine is a 2016 Z51.
Thanks...!
Old May 26, 2021 | 06:55 AM
  #77
NashvilleGrandSport's Avatar
NashvilleGrandSport
I have BOTH the PSS and AS/3+. I set cold at 30 psi in both sets per door jamb.
To Tire Pressure
Old May 26, 2021 | 12:21 PM
  #78
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Me too!
Old May 26, 2021 | 12:50 PM
  #79
sgt1372's Avatar
sgt1372
I raised the air temp in all 4 of the non-run flat Michelin PSS tires on my car to 32.5 psi. The computer reads the running tire pressures at about 36-37. Have had no traction or any other problems using these tire pressures.
Personally, as between 30-32.5, I don't think it really matters for the street.
I just raised the psi a bit because it made me feel better in terms or providing some additional rigidity to the extremely low sidewall PSS tires in order to reduce the possibility of damaging the bend/crack prone wheels on the car.
Old May 26, 2021 | 01:59 PM
  #80
Har-ray's Avatar
Har-ray
My door jamb reads 35 PSI. Sometimes, in the hot Fla. summers, on the highway; the pressure will go up to 40PSI!
NOTE: I did get 40k mi. out of the PSS tires, keeping them st 35 PSI cold.
