How do you clean the windshield?
Old Sep 29, 2020 | 09:09 PM
Avanti's Avatar
Avanti
Ivory hand-soap and water.
Old Sep 29, 2020 | 10:21 PM
dukecityevo's Avatar
dukecityevo
This is a great product to reach into those tight spots on the inside windshield. I mix a spray bottle with 50/50 water vinegar mixture.
Amazon Amazon
Old Sep 29, 2020 | 10:45 PM
EASonBASS's Avatar
EASonBASS
I use sprayaway with a magic eraser or artificial clay thing. Second pass with glass cleaner and mf towels. Follow that with adams brilliant glaze. This last bit leaves it clear and streak free.
btw: I hate cleaning the inside of the windshield.
Old Sep 29, 2020 | 11:05 PM
4thC4at60's Avatar
4thC4at60
Another vote for Invisible Glass
Old Sep 29, 2020 | 11:26 PM
TheRobSJ's Avatar
TheRobSJ
Stoners Invisible Glass is pretty much the hands down pick for general use by many detailers.
If the glass really has a bad film on it, then Angelwax Vision cuts through it pretty well.
There’s also a microfiber pad on a wand thing that I use to get way down in the front of the windshield. Pretty much the only way to get that strip of glass right in front of the HUD bezel.
Everything is in a video here...
https://www.obsessedgarage.com/products/angelwax-vision
Old Sep 29, 2020 | 11:57 PM
MMD's Avatar
MMD
Whatever cleaner you use you need to find out first if it is ammonia free if you have windows that are tinted. Better check first or you'll pay the price.
Old Sep 30, 2020 | 04:40 AM
Originally Posted by NortonCO
Adams' Glass Cleaner and Glass Towels work well for me.
This is what I use too and it works very well.
Old Sep 30, 2020 | 07:34 AM
devron11's Avatar
devron11
Default Use the Swiffer with your MF towels and cleaner
Old Sep 30, 2020 | 08:41 AM
jim.bennett.nji's Avatar
jim.bennett.nji
Navigator
Thank you all!
Old Sep 30, 2020 | 11:33 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Once in a while I will use clay bar on the glass using Windex as the lubricant. Then Invisible Glass, followed occasionally with Adams Glaze.
Old Sep 30, 2020 | 02:54 PM
yokennyr's Avatar
yokennyr
Yep...Adams Brilliant Glaze is awesome for the inside of the windshield.
Old Sep 30, 2020 | 04:28 PM
Maxpowers's Avatar
Maxpowers
I too like Invisible glass. Might give Adams a try next time.
Old Oct 1, 2020 | 12:03 PM
  #33
HDBADDOG55's Avatar
HDBADDOG55
Originally Posted by jaki30
75% distilled water, 25% alcohol.
Use a Mr Clean white eraser, then polish with a microfiber towel.
I agree!!
Old Oct 1, 2020 | 03:54 PM
  #34
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
Originally Posted by spoolin98
Order this and don't look back, best glass cleaner I have ever used hands down. Just soak it in plain old water and ring out as much water as you can, then clean your glass.
https://www.amazon.com/Microfiber-Su...s%2C218&sr=8-1
This ^^^. I made my wife a true believer of the results of this product when she used it on the house windows!
Old Oct 1, 2020 | 10:10 PM
  #35
jim.bennett.nji
Navigator
Ya think?
(that comment was meant for the gent that told me the film was on the inside of the windshield...)
Old Oct 2, 2020 | 11:27 AM
  #36
Supraman45's Avatar
Supraman45
I had great success with a glass cleaner on an microfiber towel and then a clean MF towel wet, and squeezed as dry as I could get, it to go over the windows. The remaining moisture cleans any remaining film and leaves nothing, and dries immediately.
Old Oct 2, 2020 | 12:19 PM
  #37
Josephu's Avatar
Josephu
Originally Posted by MMD
Infrared radiation creates off-gassing of the plastic dashboard and all other components within a vehicle. These out-gassed plastic molecules get into the air and then condense on glass surfaces. I have tried every windshield cleaner there is and none will clean this film from a window without streaking. I finally have found a product that does clean the windshield spotless without any streaking. It is also as a great general purpose cleaner and works great for grease and oil. Great cleaner to use in the garage. I mix about 1-2 fluid ounces of Lestoil in a small pail of warm water. I'll use a small plush microfiber towel and wet the towel by immersing the towel in the pail and then ring it out so the towel is dampened but not dripping. I'll then clean all the windows in the vehicle inside and out with this towel. I'll follow up with either a paper towel to dry or use another dry plush microfiber towel. Either will work well. This cleaner just melts away grime on any surface and will leave your windows spotless. It's the best cleaner I have found anywhere. You can find it in many grocery or hardware stores. Give it a try. I'm sure you will become a big fan.
Same idea, but I use Dawn dish soap......
