Optima Battery
The OEM battery is not an AGM, it is flooded. The AC Delco direct replacement is also flooded. It is pure speculation the system is designed to also accommodate AGM batteries. As you point out "we will will never know the algorithms that are used."
If you come across anything from GM stating AGM batteries are appropriate for the Corvette, pass it along.
Must assume that the GM charging system is the same as it has been for decades. A simple ferroresonent system that does not control the charging rates. As the battery charges, the battery voltage comes up. The alternator output stays the same therefore difference between battery voltage and alternator output voltage gets smaller. As the difference gets smaller the charging rate drops (less amps into the battery), until the battery is full. Thereafter there is a small charge going into the battery because the battery can't get up to the alternator voltage in most cases. Simple as that. And this has worked for flooded wet cells for decades.
In the case of any AGM step charger, the initial charging voltage ramps up to maintain a constant charging current (bulk charge, 10s of amps depending on size of battery). When the voltage of the battery rises to a predetermined amount (typically in the high 14v range) the charging current is reduced as this voltage is maintained (absorption charge). Then the charging voltage drops to somewhere in the mid 13v range when the battery will absorb no more current. It then enters the float phase. Graph attached. Apologize if TMI for some....
Point is that this is what it takes to properly maintain any AGM battery (yellow top, pink bottom, black square etc). Not doing this shortens battery life but won't hurt anything. This was painfully learned in the marine industry as the new AGM batteries came out but the charging systems were old style designed for flooded wet cells. Today's marine chargers all have selections for different battery types or they just do let's say AGM and Gel cells. Flooded wet cells work perfectly fine with the Step Charging required by AGMs and Gel Cell batteries.
To summarize. Your buddy may swear by them. His cousin may have had to replace the yellow top many times, etc etc etc. Depends on use and how they are maintained. Those little maintainer chargers don't come near the charging rates needed to keep an AGM healthy if hooked up in discharged states (other than slight). Only a proper step charger should be used. If you have a maintainer that does step charging, great, use it. If you have an AGM battery make sure it does step charging. Worst case is if you go somewhere, then drain the battery using loads with the engine off, then have to depend on the alternator to recharge it while going home. But if you need this moderate discharge over longer period of time an AGM (a type of deep cycle battery) is probably for you. The only thing you will affect is the cash in your pocket in the long run.
Oh, and calling Optima may be like calling the Chevy dealer and asking if you should order a C8 :-)..
Must assume that the GM charging system is the same as it has been for decades. A simple ferroresonent system that does not control the charging rates. As the battery charges, the ....[snip]...
CTEK believes 4.3 amps is sufficient current to charge a 12V AGM. Also, numerous owners here are reporting at least 3 year life expectancy with this battery.Do you have access to a notional charge diagram for a typical 12V AGM battery that has been deeply discharged? I'd like to explore this topic further.
"As with all gelled and sealed units, AGM batteries are sensitive to overcharging. A charge to 2.40V/cell (and higher) is fine; however, the float charge should be reduced to between 2.25/cell (13.5V) and 2.30V/cell (13.8V) (summer temperatures may require lower voltages).
"Automotive charging systems for flooded lead acid often have a fixed float voltage setting of 14.40V (2.40V/cell); a direct replacement with a sealed unit could overcharge the battery on a long drive. Overcharging AGM batteries kills them. See, e.g, click and click.
As @Submerge noted earlier, this will not hurt the car but decreases AGM battery life.
Those contemplating going non-OEM and installing an AGM battery should take into account the downsides of doing so.
Whether the individual owner considers the consequences is entirely up to them.
Then there is what we do know: The C7's OEM battery is flooded. The replacement OEM is flooded. Unlike BMW, the Corvette does not include the ability to tell the car what type of battery has been installed. We have no information the system self-configures to AGM. Overcharging AGM batteries kills them.
But what a CTEK does is meaningless; a C7 does not include a built in CTEK charger as part of its electrical system.
In fact, as you pointed out previously, "We will will never know the algorithms that are used to control and direct Corvette's battery control module." Thus, evidence a CTEK treats AGM differently does not mean a C7 does. It is however evidence that AGM and flooded batteries need to be treated differently.
Of course, it is your car. The battery police are unlikely to learn you used a different battery type than OEM in your car.
